Author Topic: K10 motor mounts  (Read 4148 times)
Offline ajdmello
K10 motor mounts
« on: June 05, 2016, 04:14:24 pm »
Ok guys i bought a frame to start my build with told it was from an 85 4x4 and it had motor mount on it.  also had plates on them to move the mount farther forward and was missing a crossmember and the other one was all bent up like they needed the room for a big block maybe not sure but i want to know if theses are right for a 350 and in the right place
Offline ajdmello
Re: K10 motor mounts
« Reply #1 on: June 05, 2016, 04:39:38 pm »
here is the pic...finally
Offline Engineer
« Reply #2 on: June 07, 2016, 10:18:21 pm »
Looks ok to me. Mounts seem to line up with the bump stop bracket, or at least where it is supposed to line up.
Now the crossmember that is a different story. It is supposed to be bolted to the motor mount brackets.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline ajdmello
« Reply #3 on: June 08, 2016, 08:42:11 am »
Ok thought they seemed to go there but the ones on my 6cyl truck had a few more holes so i wasnt 100 percent sure.
That crossmember came out of the 6cyl also im thinking i have to take off the bolts and then the vertical parts come off  and i can bolt it right to the mounts.
