Author Topic: 85 C20 is gone and in its place a 84 C1500 GMC  (Read 7273 times)
Offline Jim_Hensley
« on: June 06, 2016, 12:49:28 pm »
1984 GMC 1500 305 LE9 700r4,and 3.08 10 bolt, heavy duty rear springs, 6100Lb GVWR 118K miles
Only bad part..
Offline Jim_Hensley
Re: 85 C20 is gone and in its place a 84 C1500 GMC
« Reply #1 on: June 06, 2016, 08:45:56 pm »
Gave her a bath today and figured why not wax up my patina..lol  cleaned up pretty nice.
  Tailgate before..
Tailgate after .
« Reply #2 on: June 08, 2016, 10:35:55 pm »
nice. makes me want to wax my trucks....... nm im to lazy
Offline Jim_Hensley
« Reply #3 on: June 09, 2016, 08:16:49 pm »
just start on one fender and it is contagious I really didnt want to bother wax mine  but i did one spot and I just had to see how the rest turned out.
Offline Jim_Hensley
« Reply #4 on: June 25, 2016, 05:21:32 pm »
Well i took the carb off and pulled it apart and come to find out the idiot, didn't pay attention to the Primary metering rod hanger and screwed the top down on to of the metering rods out of the bores and ruined the primary rod piston, Luckily I had a spare Qjet to rob parts from , but I got it all back together and it runs so much better but I think I fouled a plug running with the carb before, good news is I thought the trans was bad cause it wouldnt shift into 3rd at all before, but I couldn't hardly drive the truck , but the other day I took and jacked up the rear and ran it up and I guess the trash  finally cleared out of the valve body and it started working , now the more I drive it the better it works. I was so relieved.
Offline Shaker
« Reply #5 on: June 27, 2016, 01:32:32 pm »
Wow that shined up pretty nice, I think I might try that after the engine in mine is back together. Hopefully it is "Contagious"
Offline RossCravens
« Reply #6 on: June 29, 2016, 01:29:27 pm »
That was a dramatic difference with a little wax and some elbow grease!  I may have to give it a go with mine now.  What kind of wax was that?  It would really be much easier on me if you would do it for me!
'86 GMC C10 SWB--454
"There is no replacement for displacement"
'06 Chevy 2500 LBZ
Gig 'Em Aggies
Offline Jim_Hensley
« Reply #7 on: June 30, 2016, 05:40:39 pm »
This was just Mothers carnauba cleaner wax .  Might try the buffer and see how that turns out, I need some gas tanks though.  pickup stops up.  While Im waiting for those I swapped out the rims and tires over to my Latest van and installed some 275's in place of the rotten ass 255/70's the guy had on the front. So the Van is rocken the rallyes and its got 255/60's up front and 275/60's in the rear .
 and I stuck the ARE rims from the van on the truck and I think they look pretty good, Might keep em on there and add some 255/70's in place of the rotten Goodyear 235/75 on it now.
