Author Topic: shaving drip rails  (Read 5844 times)
Offline dirrty d84
shaving drip rails
« on: March 08, 2006, 10:36:00 pm »
i want to shave my drip rails but i was wondering if it would leak around the door. or if theirs anything i can do to keep it from leaking after their shaved. if it will cause a problem, ima just leave it alone. thanks
Offline bigblock73
  • Yeller
Re: shaving drip rails
« Reply #1 on: March 08, 2006, 09:50:00 pm »
If you ditch the drip rails, water will run off the roof and get you a little wet when you open the door.  If you have patience, just wait a couple seconds then exit the vehicle...proble solved.  Personally, if it is a driver, and you don't plan to customize it much...keep 'em on.  If you plan to customize your truck and won't be driving it all over the planet...get rid of 'em.  :)
Jeff
'73 swb 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline shaved80
« Reply #2 on: March 09, 2006, 12:17:00 am »
it really isn't noticeable with them gone, i got just as wet getting out of my dads truck with drip rails as i do with my truck without...it's only a few drops of water
shaving drip rails
« Reply #3 on: March 09, 2006, 10:28:00 pm »
or you could paint them to make them blend in better.
