Author Topic: No Casting Numbers on a QuadraJet  (Read 6344 times)
Offline jman340
« on: June 11, 2016, 03:24:53 pm »
I just picked up a quadrajet that I intend to rebuild and swap onto my truck. I was told it was off a truck, but they didn't know what year. It's non electric, but does have an electric choke. I've read on a few websites that it should have a casting number above the secondarys on the drivers side, but it does not. It does have GM stamped on it in a few places and has some sort of alpha numeric grid on the back. Any way to figure this out so I know what kit to buy, or is there a kit that covers a wide range of years?
Thanks
Re: No Casting Numbers on a QuadraJet
« Reply #1 on: June 11, 2016, 06:15:20 pm »
take pictures
Offline middleg
« Reply #2 on: June 11, 2016, 08:36:25 pm »
I don't think quadrajets really had casting numbers on them but it should have a number stamped on it that will help you decode what year make and engine it was originally on.
1978 C10 Big 10 W/ 350 & 3 on the tree
Offline jman340
« Reply #3 on: June 12, 2016, 09:42:16 am »
Mine is totally blank in that area. Looks like it was cast that way.
Offline Stewart G Griffin
« Reply #4 on: June 12, 2016, 07:11:25 pm »
Do you have a circular stamp somewhere near the accelerator pump?
Offline Fourxbob
« Reply #5 on: June 20, 2016, 09:34:05 am »
Numbers are probably just coated with dirt and grease. Clean it up and look again
Sent from my XT1526 using Tapatalk
Offline blazer74
« Reply #6 on: June 20, 2016, 04:58:14 pm »
Nos float bowls that were never set up on specific vehicle will not have those application numbers.
Could have been bought and installed later by an individual.
The part number will be the circular number cast into the housing, but that won't tell you how it is set up.
