Author Topic: Door Jamb Rust Repair Question  (Read 9672 times)
Offline SmokeShow
« on: June 14, 2016, 12:04:17 pm »
How do you fix this? I'm not seeing any patch panels available for this so I assume they'd have to handmade? Ugh as if body work weren't expensive enough as-is, throw in something completely "custom" or handmade and it's liable to be super expensive. *sigh*
Project: 1983 GMC K30 Crew Cab Short Bed, D60 front w/ LocRite Locker, 14BFF w/ Lincoln Locker, 4.56 Gears, NP205 Transfer Case mated to Muncie SM465.  Have 06 Duramax/Allison waiting to be installed
Driver: 2002 Chevrolet 2500HD EC SB D/A
Offline SmokeShow
Re: Door Jamb Rust Repair Question
« Reply #1 on: June 15, 2016, 08:45:16 pm »
Nobody has any input?
Looks like a metal shrinker/stretcher would be needed to reproduce that stepped track.
From a fundamental standpoint, does anyone see a need to have that area be an overlapped 2-piece joint there? Where two pieces of metal sit against each other it seems to hold water & rust out over time. Seems that area could be remade to be one butt-welded seam instead & hopefully stop that area from ever rusting like that again, no?
« Reply #2 on: June 16, 2016, 07:05:36 am »
give our body guys some time.
Offline DanMcG
« Reply #3 on: June 17, 2016, 02:52:43 am »
I'm no body man, but if it was me I'd first remove the paint and see how extensive the damage is. maybe it's not as bad as it looks. (yeah i'm an optimist) Then locate a donor truck and cut off the chunk of jamb ya need. Then replace the whole thing or just weld in small sections where the damage is.  I'm guessing somebody here has a spare one they could ship to ya for a reasonable price.
« Reply #4 on: June 19, 2016, 07:23:58 pm »
I'd sand blast it first, see how bad it really is.
Offline montrosepatriot
« Reply #5 on: January 07, 2017, 04:09:02 pm »
when produced new the ELPO dip only penetrated the exterior sheetmetal not the insides - this might warrant the removal of the entire roof panel once the spot welds r located
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #6 on: January 08, 2017, 11:36:57 am »
Pull the windshield and look for rust there, back of cab and rear window too. Rust up the door jamb typically means more rust below
Double lap has more structural rigidity then butt weld, plus from an assembly standpoint overlap is easier.
FYI the top roof is a combination of welded and brazed joints
 1986 Chevy K30(under repair)
« Reply #7 on: January 08, 2017, 02:08:45 pm »
That piece isn't made.  You are looking at fab work or a donor.  I agree with the others on cleaning it off and checking damage.
The overlap is there by the way the truck was made, piece spot welded to other pieces.
