Author Topic: Defroster Problem  (Read 4076 times)
Offline rdhack
Defroster Problem
« on: June 19, 2016, 01:54:40 pm »
1982 GMC K1500 with AC that does not work/not hooked up. The Defroster works BUT only when the engine is revved up to higher RPM's. Would this be a Vacuum leak and if so where would I start looking? Thanks
Offline LTZ C20
Re: Defroster Problem
« Reply #1 on: June 19, 2016, 02:03:08 pm »
The heater core is restricted. Increased engine rpm means increases pressure and increased flow thru the heater core. Start by removing the heater core hoses at the intake manifold and radiator, hang them over the fender into a suitable catch can (large drain pan or 5 gal buckets) and flush with a garden hose. Do this alternating between both hoses being either the drain or supply from garden hose.
Note: the hose removed from the intake manifold is the supply to the heater core and the hose from the radiator is the return from the core back to the radiator. So start with the supply line and then move to the return line. Using the return line is back flushing the core and may help clear out and clogs.
Flush until the water is as clean as you can get it. Report back with your results.
« Last Edit: June 19, 2016, 02:04:48 pm by LTZ C20 »
LTZ Cheyenne C20
Offline rdhack
« Reply #2 on: June 19, 2016, 03:33:44 pm »
Hahaha, Immediately after posting this I walked outside and looked around and noticed a vacuum line hanging loose off my vacuum storage ball........that is all it was. Works fine now.
Offline LTZ C20
« Reply #3 on: June 19, 2016, 04:24:22 pm »
That works too.
LTZ Cheyenne C20
