Author Topic: Driveline Vibration  (Read 97431 times)
Offline philo_beddoe
  • 77 C-10
Driveline Vibration
« Reply #105 on: October 18, 2016, 06:17:37 pm »
Ok, but i do know that the slip yoke is well in there, the new dshaft is almost an inch longer than the old one, plenty of grab.
I have a hunch the tranny mount is too thick.
Re: Driveline Vibration
« Reply #106 on: October 18, 2016, 06:59:57 pm »
Check to see how centered your fan is in the shroud.  If you are a lot closer to the bottom your engine is tilted and you may be right
  • 77 C-10
Driveline Vibration
« Reply #107 on: October 18, 2016, 08:48:07 pm »
Ok, i never thought of that. Will check..
Just checked, its even all around. Maybe tail end of tranny is tilted on one side....slightly?
« Last Edit: October 18, 2016, 08:55:35 pm by philo_beddoe »
  • 77 C-10
« Reply #108 on: October 19, 2016, 07:20:47 am »
Well, on the way into work this morning I did feel the typical vibe (like an in and out drone), it wasn't very prominent, but it was there (with my 240 lb. simulated pass). My commute to work is 11 miles, which includes about 1.5 miles of hwy. About half way to work I could hardly feel it, then on the hwy it was so smooth, felt like a brand new caddy, no vibe whatsoever. And it was never that smooth w/o the weight on the pass side.
I'm starting to get confused again, what in the world could be warming up AND with the weight on the pass side cause the vibe to totally go away? Or maybe something is not warming up? I'm going to drive with the weight on the pass side for a few days, try to develop a pattern.
« Last Edit: October 19, 2016, 07:41:19 am by philo_beddoe »
Offline MrFiveOh
  • The Local Po-Po
« Reply #109 on: October 19, 2016, 08:32:40 am »
Id say drive it until something actually breaks, My vibration drove me crazy but it didnt affect the actual performance of my truck. Eventually i found it though, im sure you will too. Keep giving updates and im sure something will come up.
1974 C-10 AKA "Smurf"
  • 77 C-10
« Reply #110 on: October 19, 2016, 11:02:04 am »
That was one theory i was considering. But i get annoyed when things arent perfect. If my dome light burns out, why even drive the truck! Lol
Offline MrFiveOh
  • The Local Po-Po
« Reply #111 on: October 19, 2016, 11:39:29 am »
I understand that. I know my truck and when the slightest thing changes it bugs until i figure it out.
  • 77 C-10
Driveline Vibration
« Reply #112 on: October 19, 2016, 05:02:08 pm »
Well the pattern is continuing the same. When truck has sat and is totally cold, i get my vibe for a few miles then when i come to a stop or whatever and start back up, it smoothens out like a new caddy. But only with the added weight on the passenger side. I cant make any sense of it.
« Reply #113 on: October 19, 2016, 05:22:20 pm »
How are your body mounts?
  • 77 C-10
« Reply #114 on: October 19, 2016, 07:48:00 pm »
Not exactly new rubber, but not rotted out either. How many are there, i'll double check.
  • 77 C-10
Driveline Vibration
« Reply #115 on: October 19, 2016, 07:51:54 pm »
Tranny mount w/o add weight on pass side and with.
This pic is with the added weight, post 103 is without.
« Last Edit: October 20, 2016, 09:32:57 am by Irish_Alley »
Offline gwcrim
  • Far from a Newbie
« Reply #116 on: October 19, 2016, 08:12:26 pm »
Id say drive it until something actually breaks...
That's how I feel about my vibration.  I'll get to finding it.  If it goes first?  Hope it's not catastrophic.
  • 77 C-10
« Reply #117 on: October 19, 2016, 08:51:03 pm »
I hear ya, i'm starting to get to that point. But when you find a clue, you have new hope, only to once again go through dissapointment and personal anguish. Lol
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #118 on: October 19, 2016, 09:16:13 pm »
I think you forgot to post a pic...
 1986 Chevy K30(under repair)
Offline Rattler12
  • Old Geezer
« Reply #119 on: October 19, 2016, 09:17:53 pm »
You got cheap tires ?   If its there when cold and goes away after a few miles?  Maybe flat spots on the tires from setting then rounding out again when warmed.....?????
83 C-10 shorty 454, 5spd, 3:73 posi
