Author Topic: Engine bay wiring help  (Read 3586 times)
Offline winky
« on: July 16, 2016, 09:05:45 pm »
i need some ideas for running wiring in my engine bay neatly... ill be running 3-4 sets of aftermarket lights, in cab winch controls, relays, plus the original wiring for every thing. i want to try and keep it as neat as possible without having wires everywhere. any advice or pics would be great. im looking into using nylon cable clamps like these
http://www.delcity.net/store/Nylon-Cable-Clamps/p_801515
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Engine bay wiring help
« Reply #1 on: July 17, 2016, 07:56:44 am »
use corrugated split loom, or even the wire braid(this is harder to pull over bundles of wire, then split loom) and then try these clips, these are what normally come stock, and don't require you to remove completely to fix/add to the loom.
http://www.clipsandfasteners.com/Clips_Wire_Loom_s/78.htm
split loom is also easier to branch off, just pull the wire out, and throw a little electrical tape around loom on either side of the wire to prevent it from coming all the way out
 1986 Chevy K30(under repair)
