Author Topic: going to swap bed but one problem  (Read 5237 times)
Offline 777884chevy
« on: April 08, 2006, 04:29:00 pm »
found a bed off of a 75 chevy. Going to swap it to my 84 gmc. You fill the gas tank on the drivers side on the gmc. On the 75 bed it is on the passenger side. I don't need dual tanks and I don't want to cut a hole in the rust free bed so I can probably buy a brand new tank for the other side and run lines to it and just take out the driver side tank. Does this sound correct?
Offline bfofish
Re: going to swap bed but one problem
« Reply #1 on: April 08, 2006, 05:52:00 pm »
the tank is the same for both sides,as well as the mounting brackets.
« Reply #2 on: April 09, 2006, 10:30:00 am »
what he said except you need to turn the tank around or swap the brackets end to end.
