Author Topic: Dually conversion?  (Read 6185 times)
Offline MitchThor14
Dually conversion?
« on: July 20, 2016, 05:21:28 pm »
Hello everybody, i have a 1984 C20 and was wondering if i could take an 84 dually rear end and springs and just drop them underneath my truck? Is the frame the same width? Thanks.
Sent from my LG-H636 using Tapatalk
Offline fitz
Re: Dually conversion?
« Reply #1 on: July 20, 2016, 07:02:51 pm »
You will have to use the 1 ton spring hangers.
Offline LTZ C20
« Reply #2 on: July 20, 2016, 08:17:26 pm »
The frame is narrower in the rear on the dually.
LTZ Cheyenne C20
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: July 21, 2016, 08:02:23 pm »
Umm not on these style trucks, on these trucks the frames are the same, the spring hangers are narrower to bring the springs in to clear the backing plate-at least on the two cab and chassis and the one crew cab dually I've seen. Later trucks(1988+) the frame widths can vary.
With that being said, I'm pretty sure the dually axle off of a pickup will work, you just need to reweld new spring perches, if it is a cab and chassis axle, then you need the hangers as the axle itself is narrower, meaning less space between the backing plates
 1986 Chevy K30(under repair)
Offline LTZ C20
« Reply #4 on: July 21, 2016, 09:28:29 pm »
Well nevermind then lol.
LTZ Cheyenne C20
« Reply #5 on: July 28, 2016, 08:26:10 am »
2wd hanger are also shorter than 4wds
« Reply #6 on: July 29, 2016, 06:03:00 am »
Dually? Or cab, and chassis rear end?
