Author Topic: Tilt Steering Help  (Read 6674 times)
Offline noclrnce
Tilt Steering Help
« on: July 25, 2016, 07:23:17 am »
I have an 83 k10 with a non tilt column and manual transmission . Ive been watching craigslist and eBay hoping to find one with tilt but am having no luck. I have found the universal gm columns on eBay but have some questions. They come in two sizes..... A 28 and a 32. I'm a big guy with a single cab pickup so could I use the 28? What are some things I need to consider before commiting to a universal part? How much trouble am I going to have?
Online zieg85
Re: Tilt Steering Help
« Reply #1 on: July 25, 2016, 10:58:08 am »
Welcome from the St. Louis area.  Tilt columns for a 4 speed floor shift are hard to find but not impossible.  I snagged one for my 85 but I had to buy the whole truck for it.  As far as length for an aftermarket I can't comment but with a smaller steering wheel you can gain some extra belly room.  Here is my 85 C20 454 4 speed with a tilt column and a '92 Chevy Lumina wheel.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #2 on: July 25, 2016, 04:34:58 pm »
I have been looking for a tilt wheel for my truck too.
Offline noclrnce
« Reply #3 on: July 25, 2016, 09:49:59 pm »
Even the trucks are hard to find in my area.
Offline roundhouse
« Reply #4 on: July 25, 2016, 10:16:28 pm »
Check your local craigslist or a hot rod shop
Several companies make GM Collumns since that's what all the hot  rods use
I think the blank  collar from your manual column will slide onto a automatic column
Offline noclrnce
« Reply #5 on: July 25, 2016, 10:17:46 pm »
Been on Craigslist since I bought the truck. Still a no go. No hot rod shops in my area. That's why I went to eBay.
Offline roundhouse
« Reply #6 on: July 25, 2016, 11:42:12 pm »
They go for about $150 around Atlanta
There's half a dozen on CL Atlanta
Doubt you'll ever find a manual Trans one
But the collar should interchange
It does on fords
Offline noclrnce
« Reply #7 on: July 26, 2016, 08:19:02 pm »
Is there anything else I can do to give me a little more room? What other steering wheels will work that don't look horrible? Would different seats help?
Online zieg85
« Reply #8 on: July 26, 2016, 09:04:16 pm »
Mid-late 70's Camaro steering wheel works.  85 on seats the seat backs have less padding and give a little more room.  If you can find a bench seat out of a 1991 Suburban they work best but do not fold forward to access behind the seat.  You will need to use the slides off of your seat.
Offline LTZ C20
« Reply #9 on: July 27, 2016, 12:30:03 am »
I have the RPO code NK4 4-spoke sport wheel for Camaro, Chevelle and Vega.
LTZ Cheyenne C20
