Author Topic: 4 door rusty  (Read 3981 times)
Offline Micbrewer
4 door rusty
« on: July 30, 2016, 11:29:46 pm »
I got this wonderful cab for a total of 80 dollars, the rust on these floors are out insane. I just wanted to see if anyone has done their own research to see if 2 door inner door jamb patches can be made to work on my 4 door cab
Offline Micbrewer
Re: 4 door rusty
« Reply #1 on: July 30, 2016, 11:36:38 pm »
Good side and now on to the bad side
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 4 door rusty
« Reply #2 on: September 02, 2016, 06:54:56 pm »
Didn't see this till now, but from what I see, someone used a 2 door cab floor to patch the rear-you can tell because, 1-they plasma cut off  some of the floor support, but not all of it. 2-there is a weld line with sealer-all the burbs and crews I have seen the floor is only a 2 piece. you can see the original part line just ahead of the middle support. 3- the inner rocker is also part of the floor from the factory.
 1986 Chevy K30(under repair)
