Author Topic: Replacement tach needle  (Read 3616 times)
Offline willi2ds
« on: August 05, 2016, 11:40:45 pm »
So I bought a factory tach cluster awhile ago and at some point being stored the tach's needle broke, the other needles literally crumbled when u touched them as well. I know I can swap the other needles from another parts truck I have, but any suggestions on the tach needle? I'd rather not have to buy another tach when I know this one works.
Any help would be appreciated.
Offline LTZ C20
Re: Replacement tach needle
« Reply #1 on: August 06, 2016, 01:32:29 am »
It should be the same needle as the speedometer.
LTZ Cheyenne C20
Offline willi2ds
« Reply #2 on: August 06, 2016, 04:06:40 pm »
Ok thx, I thought I read the speedometer needle needed to be turned instead of pulled.
Offline willi2ds
« Reply #3 on: August 06, 2016, 04:20:22 pm »
Any tips on getting the needle lined up correctly? I thought about hooking up an autometer tach and let the truck idle to get a base number then try and match that with the cluster tach
Offline LTZ C20
« Reply #4 on: August 07, 2016, 12:41:38 pm »
That should work as long as both tachs are working properly.
LTZ Cheyenne C20
