Author Topic: keystone body panels  (Read 17506 times)
Offline usmcchevy
« on: May 06, 2006, 01:28:00 pm »
does anybody have any experience with keystone body panels for the 73- 80 trucks. i can get front fenders and a core support. does this brand seem to line up pretty well.
Re: keystone body panels
« Reply #1 on: May 06, 2006, 10:45:00 pm »
I have used about every after market brand of panel out there including Keystone, They all need to be bent and twisted into place one way or another. I have even had to fanagle factory panels a bit before.
Offline 80stepsideguy
« Reply #2 on: May 07, 2006, 01:07:00 am »
Hey USMC
i may have a pass side 73-80 aftermarket fender if your interested.Currently its on the truck but will be comming off within a couple of weeks,i currently dont have a camera to show you but if n when i do and your still interested i`ll take some pics.I`ll take 40.00 + shipping.I do have a drivers side but its not worth it its rotted in the front and starting to in the back and it be better to find a cleaner 1..Reason im selling it cause i am putting a set of clean used GM fenders i got for it..If your interested PM me and let me know..
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline Ziptar
« Reply #3 on: May 07, 2006, 06:40:00 am »
Can I buy from Keystone if I don't have a business?? I just found out that they have a warehouse about six blocks from where I work.
I'd rather have OEM stuff but I am having a hard time coming up with Good used front end sheet metal.
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
Offline roundedline
« Reply #4 on: May 08, 2006, 04:49:00 pm »
Nothing you purchase will just bolt on and line up, even FACTORY GM pieces.  This is where bodymen make their money.  Making stuff line up and look right.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline usmcchevy
« Reply #5 on: May 08, 2006, 07:35:00 pm »
i know nothing just bolts on. but im sure some are better than other in guage and fit. i can buy them from a local guy here and i was just wondering what kind of luck people had with them. otherwise id buy them from here
Offline roundedline
« Reply #6 on: May 08, 2006, 10:33:00 pm »
Tri-Pluss makes the best fit in the aftermarket.  Goodmark also has an improved fit on the 73-80's.  Both of which I sell.
Project Su
Jimmy 2WD Project
Offline SUX2BU99
« Reply #7 on: May 10, 2006, 12:35:00 pm »
I apologize for how noob I sound in asking, but what is it that makes these replacement panels, even factory ones, not just simply bolt-on? I realize alignments have to be done but stuff like bolt holes dont' line up or what?
I would think (maybe naively) that a used factory fender would bolt on no problems, except for minor alignment.
I know my truck has all kinds of alignment issues on my front end sheet metal   lol   Oh well, hopefully I can figure it out myself.
Offline roundedline
« Reply #8 on: May 10, 2006, 05:56:00 pm »
All the holes on a fender for example are oversize to the bolt (speaking of the rear).  This allows up/down, front/back movement.  They also take shims behind them to space them out from the body.
Some of the cheaper sheetmetal have the largest tolerances and when you pair that with other parts, the room for error gets larger.  I have seen bodymen bend the top portion of the 73-87 doors to get the fit tighter.  I have personally elongated holes at the rear to have the fenders fit properly, etc.
Does that help?
Project Su
Jimmy 2WD Project
Offline SUX2BU99
« Reply #9 on: May 11, 2006, 12:52:00 pm »
It certainly does. Thank you.  All these little things I like to know before diving into realigning body panels. :)
« Reply #10 on: May 12, 2006, 07:10:00 am »
Chris, you been watchging me work? Yeah I have had to bend the top front of an aftermarket door in over an inch, & the back of the same door out over an inch. Have had to make the top back bolt hole in a fender a 1/4 inch longer, bolt the bottom back tight, and used a porta power to push the core suport away from the fire wall to get the door fender line right. Have had to completly move the hinges around on the cab to get doors to fit etc.
Edited by: Blazin at: 5/13/06 12:12 am
Offline roundedline
« Reply #11 on: May 12, 2006, 11:20:00 am »
It sounds like I have been doesn't it.  I haven't done a door that way, but I did install a set on a truck and they didn't fit properly and the person that owned it said he didn't like the fit, and I told him we could bend it as I have seen it done, but he didn't want to.  The wierd part was the doors he replaced the new ones with only needed the bottoms fixed, so I kept them, since he though they were junk. :D
This is the door and it fit perfect other than what you see on the inside front (it had a hole on the outside like all of them do at that area):
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 5/12/06 10:20 am
Offline Bandit 8
« Reply #12 on: May 13, 2006, 03:59:00 pm »
I have a question about door fit now that the subjaect came up.  I just replaced the cab supports on my 83 tk along with replacement planels here and there.  I took both doors off and replaced all weatherstripping.  When i put the doors back I lined up the hinges with original marks and now door close really hard. I know that the weatherstripping takes time to "settle in".  But the body line is straight but the top is out 1/2' maybe a little more.  Does this door neeed to be bent at the top and if I do will that make the door close easier?  Right now no air or water gets in.   Thanks for and answers in advance.                 Jim:)
