Author Topic: Fuel Problem  (Read 7267 times)
Offline Mailoh213
Fuel Problem
« on: August 09, 2016, 06:50:33 pm »
New to this forum business so please be kind.
I have a stock 1973 Silverado 350 SBC. Everything from the fuel pump to the carb has been replaced. Yet, I'm still having problems getting fuel to the carb. Little glass filter by the carb has fuel in it, yet it hesitates, stalls, has trouble starting...
Edelbrock 1406, was jetted lean. Put it on 23 for edelbrock tuning chart. Replaced spark plugs, wires, all gaskets. I just can't figure it out. I thought vapor lock but no source. Thought sender unit but again someone said not likely. I checked the floats. Broke down the carb.
Need help
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Fuel Problem
« Reply #1 on: August 09, 2016, 07:00:04 pm »
have you taken the fuel line off the carb and put the line into a can and crank the motor?   this will tell you the fuel is good from the tank to the carb by measuring the volume of fuel pumped. also have you checked the choke on the carb to make sure it is working right?
Offline Mailoh213
Re: Fuel Problem
« Reply #2 on: August 09, 2016, 08:23:37 pm »
I have not done the first suggestion yet.
Choke check to come.
Offline Mailoh213
Re: Fuel Problem
« Reply #3 on: August 13, 2016, 12:31:11 pm »
Ok. Took fuel line off the carb and got good flowing fuel into the can. Readjusted the choke, it was way lean and she fired back up. She cruises real fine but hit the gas and she hesitates and stumbles.
New accelerator pump in the carb. Checked the lines and they look ok. Put new gas cap and it helped-no longer getting air bubbles in the fuel filter.
Re: Fuel Problem
« Reply #4 on: August 14, 2016, 07:15:57 am »
do you still have points ignition or hei?
Offline Mailoh213
Re: Fuel Problem
« Reply #5 on: August 14, 2016, 08:57:39 am »
Hei
Re: Fuel Problem
« Reply #6 on: August 14, 2016, 09:34:09 am »
hows your timing set up? manifold or ported vacuum? timing degree
Offline gunrac
Re: Fuel Problem
« Reply #7 on: August 15, 2016, 02:25:10 pm »
I had similar issues, after doing about everything, I put in a new distributor........problem solved
Never Apologize..........as it shows signs of weakness
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Fuel Problem
« Reply #8 on: August 15, 2016, 03:48:36 pm »
I agree that timing is an issue, either late advancing or just not advancing at all
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline Mailoh213
Re: Fuel Problem
« Reply #9 on: August 17, 2016, 12:14:31 am »
I think you're right.
Updated: thermostat, water pump, hoses, edelbrock 1406 rebuild, valve cover gaskets, manifold gaskets, new fuel lines, new fuel pump, new fuel filter, return fuel system put in.
This week I'll put in new spark wires and plugs.
I'll need to figure out how to adjust timing. Never done that before but some threads make it sound easy and others make it sound complicated.
Offline Ludwig Von 88
  • Mad world.
Fuel Problem
« Reply #10 on: August 17, 2016, 08:27:09 am »
It's easy, you just need an ignition strobe timing lamp, the refering inition cable is usually the first cylinder on the right when you look your truck from the front and the advance on your harmonic balancer must be flashed around 10°.
http://www.superchevy.com/how-to/45673/
« Last Edit: August 18, 2016, 04:48:22 am by Ludwig Von 88 »
Ludwig Von 88
1980 Chevy Suburban C20 3/4 ton Scottsdale.
Re: Fuel Problem
« Reply #11 on: August 17, 2016, 03:04:20 pm »
