Author Topic: 6.5 idle adjustment  (Read 13513 times)
Offline fmxr47
6.5 idle adjustment
« on: August 10, 2016, 08:46:19 pm »
Hi all, turned up the pump on my mechanical 6.5 now my idle is higher than before, I turned up the pump through the top cover and had the governor out, I'm wondering if the guide pin with the Allen and jam but is the culprit because when I removed it I forgot to count the turns... Any help is appreciated. I also tried the idle screw on the throttle plate and nothing changed
This is what I had out of there, the pin was the one coming through the back of the pump
