Author Topic: Can e-brake cause a vibration ?  (Read 20309 times)
Offline philo_beddoe
  • 77 C-10
« Reply #30 on: September 03, 2016, 08:37:09 pm »
After i installed both ujoints, the rear was perfectly smooth, but the front felt a little tacky. I watched a video made by dana spicer, and they mentioned tapping the ears or collar to free up any tension. I had to do that a few times in a few different places to try and get it to move smoothly, i never did get it perfectly smooth like the rear one. So i put the dshaft back in and went with it, and the same vibe was there as with the old joints, that is until i tapped it the other day, been smooth since. I hope its not the ears on the shaft, i doubt it. If the vibe comes back, i may have a shop install just the front ujoint.
When i looked up the right ujoint application for my truck on the dana spicer website, the front and rear showed different part numbers, however, i installed the same part number for both, the rear is right, and the correct front one would have been too large to fit, which i dont understand. The front ujoint i put in there was the exact size of the one i took out, thus giving me the vibe. I never did tap it when the old was in there though. Thats why i may have a shop just make it right.
« Last Edit: September 03, 2016, 08:40:13 pm by philo_beddoe »
Re: Can e-brake cause a vibration ?
« Reply #31 on: September 04, 2016, 07:05:19 pm »
They are the same
  • 77 C-10
« Reply #32 on: September 04, 2016, 09:06:05 pm »
Ok, thanks! That actually helps me a lot. Perhaps the splined slip yoke or dshaft yoke has a little tweak, causing that ujoint to be not perfectly smooth. I can deal with that, knowing is everything, sometimes.
  • 77 C-10
« Reply #33 on: September 07, 2016, 04:49:11 pm »
Oh, now i remember...when i was installing the front ujoint, it was hard to set the two C clips in place all the way. I had to tap them a little, thus a tight joint. Any solutions??
  • 77 C-10
« Reply #34 on: September 09, 2016, 07:07:39 pm »
Taking dshaft to a specialty shop, have'em reset that front u-joint.
  • 77 C-10
« Reply #35 on: September 16, 2016, 10:29:37 pm »
Obviously my fault. Im addressing the same problem on two posts. I will continue my driveline vibe problem on "should this do this" and end this post here.
