Author Topic: The babe, my '87 V20  (Read 85086 times)
Offline Mudder96
Re: The babe, my '87 V20
« Reply #60 on: February 28, 2017, 05:37:58 pm »
How deep is the broken bolt? If it sticks out just a little, welding a nut to it and letting a candle melt near the base should let it come out.
It's about 1/8" into the hole. I'm gonna try the nut trick and see if that does it
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #61 on: February 28, 2017, 05:43:48 pm »
I'd be worried about welding it straight to the head of its in the hole. Take a small drill(I start at about half bolt diameter) and drill into it-you could try a left hand drill bit, and oxy-acetylene heat, it may come out. Broken bolts under the head surface are the hardest to remove.
 1986 Chevy K30(under repair)
Offline Mudder96
« Reply #62 on: February 28, 2017, 05:52:45 pm »
The head is aluminum so it shouldn't weld to it but I'm gonna have to be careful and build it up and then do the nut trick
« Reply #63 on: February 28, 2017, 06:07:11 pm »
Right, forgot head was aluminum, I'm used to the cast iron ones. You shouldn't have too much trouble then with careful welding.
Offline Azryael
« Reply #64 on: March 03, 2017, 12:50:27 am »
Solid looking build! When I get my hands on the crew cab I'm looking for, I'm going to slowly amass the parts to do a LQ4/NV4500 swap from an early GMT800 in the future.
~Josh
Offline Mudder96
« Reply #65 on: March 03, 2017, 01:11:15 am »
Thanks! I'd have gone 6.0 but I got the 5.3 in running condition from my buddies truck for $500 with anything from the truck I needed so I couldn't pass it up. If I find a good enough deal on a 12v Cummins I'm gonna swap that in and put the 5.3 in my Lexus LS400 haha
Offline Azryael
« Reply #66 on: March 03, 2017, 01:22:09 am »
I'm actually also looking for another 6.0 for my Mercedes to retire it's V8 and toss in a T56 behind it as well, but I need another daily driver first.
A Cummins swap for the future truck is also on the table, as is the 6.2 DD found in the CUCV, but I'm not sure if there's a compatible manual transmission for that motor and being able to work with the transfer case for 4X4.
~Josh
Offline Mudder96
« Reply #67 on: March 03, 2017, 01:24:39 am »
That's what's nice about the NV4500, I can convert my GM one to a Dodge input shaft and bellhousing, and it will bolt right up
Offline Azryael
« Reply #68 on: March 03, 2017, 01:29:00 am »
Yeah, that is nice! It's a great box and does well with towing too.
I want to build the truck up for work, not necessarily gobs of power; so anything to increase how hard it can work is what I'm all about!
Beats spending $50k on a brand new Ram (which is the only new truck I'd consider just because they still offer a manual!) that's overly complicated by electronics and too nice to use as a "work" truck.
~Josh
« Reply #69 on: March 03, 2017, 07:50:30 am »
Quote
.....the 6.2 DD found in the CUCV, but I'm not sure if there's a compatible manual transmission for that motor and being able to work with the transfer case for 4X4.
Any GM trans that was bolted to a SBC or BBC will bolt right up to the 6.2L diesel.  NV4500, NV3500, SM465, SM420, etc...
Offline Azryael
« Reply #70 on: March 03, 2017, 12:49:24 pm »
Quote
That's great to know! As long as I have options for the future.
~Josh
Offline Mudder96
« Reply #71 on: March 13, 2017, 06:50:58 am »
Got all my valve springs in, now the rest of my lifters will be here this week so I'll assemble the motor this weekend finally! Very excited. I also picked up boggers for the truck finally!! 35x16x15
Offline Jon87V20
« Reply #72 on: March 15, 2017, 04:28:26 pm »
Very nice!
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Offline Mudder96
« Reply #73 on: March 21, 2017, 02:57:00 am »
The motor is together! Very excited!
Before and after haha
Had to get some shots of my buddies 350 going in his square with it :)
Next is a flywheel and clutch kit so I can bolt the bellhousing on and drop the motor in the truck, then I'll install the transmission after cutting a hole in the floor for the shifter
Offline Mudder96
« Reply #74 on: March 26, 2017, 06:04:20 pm »
Clutch kit, ARP flywheel bolts and pilot bearing is here, flywheel and new engine mounts will be here next week. Then I'll bolt the bellhousing on and drop the motor in probably
