Author Topic: The babe, my '87 V20  (Read 85063 times)
Offline Mudder96
Re: The babe, my '87 V20
« Reply #90 on: May 11, 2017, 02:51:31 am »
In other news I got my transfer case back in. With that being said, I am hoping and praying that I will be okay using the factory replacement throwout bearing that came with my clutch kit. But the flywheel I got offsets the clutch back .400" (because the SBC crank sits .400" out farther than the 5.3's)....so hopefully I don't have to pull the dang tranny and tcase to change that out for a different one...
Sent from my SAMSUNG-SM-N920A using Tapatalk
Offline ehjorten
« Reply #91 on: May 11, 2017, 08:22:53 am »
Your crossmember hangs from the bottom of the rails??!! Why did you mount it like that?
-Erik-
Offline Mudder96
« Reply #92 on: May 11, 2017, 01:41:56 pm »
That was an accident and I've since fixed it. That's the way it was when I pulled the drivetrain. Guys put the spacers on the bottom of the frame to push the crossmember down, which in turn helps the rear driveshaft angle. Buddy of mine pointed out that it was wrong so I fixed it with the spacers on top of the frame rail
Offline Mudder96
« Reply #93 on: May 30, 2017, 03:54:43 am »
Man I need to update this! Speed Engineering headers are in and fit great! Just had to grind a tab off my bellhousing. Plugs and wires are in, working on wiring now. I made a battery box/ECM holder too. Will be getting an Optima Red-Top battery too since they're an AGM battery which means I won't have to worry about corrosion from any vapors.
Still need to get my clutch setup, hopefully this weekend. Then finish the wiring, put the accessories on the motor and then fluids and start up time!
Offline MrFiveOh
  • The Local Po-Po
« Reply #94 on: May 30, 2017, 08:33:50 am »
Nice dude, Liking the progress, i saw the conversation on the LS swap page on Facebook, good idea on the red-top..keep it up!!!
1974 C-10 AKA "Smurf"
Offline kg264
  • Blucheez
    • Blucheez Leather
« Reply #95 on: July 21, 2017, 06:14:21 pm »
I agree, it looks waaaaay better with the chrome plate removed
Sent from my Nexus 6 using Tapatalk
1980 C10 LWB
1962 C10 LB for sale
Looking for a BBC!
Offline Mudder96
« Reply #96 on: August 03, 2017, 06:53:49 pm »
It lives!!
https://m.youtube.com/watch?v=7F_8mEOxOhY
Only things left to do in order to drive it are put gear oil in the rear end, get an LS3 belt tensioner, and put the front end back together
Sent from my SM-G955U using Tapatalk
Offline ChumminsCrew
« Reply #97 on: November 19, 2017, 07:40:09 pm »
Man I'm really digging this build! I'm doing an almost identical power train and was wondering what flywheel/ clutch configuration you went with? That's about all I'm lacking to have it ready to stab.
'90 3+3 Dually Cummins swapped 382hp/845tq
'82  K30 Prepping for 5.3/Nv4500/205
Offline Mudder96
« Reply #98 on: November 19, 2017, 07:48:45 pm »
Thanks, this truck has already finished and has left my hands but I went with:
Sachs NFW1050 flywheel
LUK-04-902 clutch kit
GM 12557583 pilot bearing
« Reply #99 on: November 19, 2017, 08:22:39 pm »
Quote
That's too bad. Thanks for the quick reply. Did you have to make any changes to accommodate the .400 difference? Im new to the forum so Im still learning the ropes.
Offline Mudder96
« Reply #100 on: November 19, 2017, 08:25:42 pm »
Quote
The NFW1050 is a special flywheel .400" thicker to combat that exact problem, well worth the money and not badly priced honestly
« Reply #101 on: November 19, 2017, 08:29:17 pm »
Quote
Quote
Awesome. This may be a dumb question but for this clutch configuration were you set up manual or hydraulic?
Offline Mudder96
« Reply #102 on: November 19, 2017, 08:35:01 pm »
Quote
Quote
I had my hydraulic setup custom built by The Syndicate Chop Shop on Facebook. Got my master, slave, hydraulic line, and custom pedal for $350, which is cheaper than finding a factory hydro system unfortunately
« Reply #103 on: November 19, 2017, 09:36:40 pm »
Quote
Quote
Why you guys quoting lol
Offline Mudder96
« Reply #104 on: November 19, 2017, 09:42:32 pm »
Quote
Quote
I've always made it a habit to quote direct questions on forums, always done it, idk lol
