Author Topic: My 305's MPGs.... :-(  (Read 12110 times)
Offline OldGray
  • Ne'er-do-well
« on: August 19, 2016, 09:36:47 pm »
I have a '79 Bonanza Longbed w/a 305.  Just put new cap, rotor, plugs, wires.  Getting about 10.5-11.5 MPG.  Seems like it should be better...?
What is the timing setting on it?  I think we have it at 10dg BTDC.
Any suggestions for boosting mileage?  THANKS
1979 Chevrolet Bonanza / 305 / LWB
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: My 305's MPGs.... :-(
« Reply #1 on: August 20, 2016, 05:11:06 am »
Check your air fuel mixture with a meter, a tuning shop should have a meter.
Is the mileage all city miles?
 1986 Chevy K30(under repair)
Offline Stewart G Griffin
« Reply #2 on: August 20, 2016, 09:28:16 am »
The first thing is to determine is if we are calculating mpgs the right way.
ARe you 2wd?
Offline FlatBlack77
« Reply #3 on: August 20, 2016, 10:43:49 am »
are you running the tank down as close to empty as possible?
if you are calculating 20 gallons in a 20 gallon tank but are only using 16-18 before refilling then it will affect the calculation.
and are you filling up based on the gas gauge or how many gallons you put it?
what size tires and transmission do you have?
Offline OldGray
  • Ne'er-do-well
« Reply #4 on: August 20, 2016, 11:16:40 am »
Trans is Turbo 350.  2wd.  Tires - 255/70-15.  Driving is mixed, but a lot of highway.  I don't drive a lot of miles.  MPGs are calculated using my FILLUP app.  I do not wait until near empty be cause my gauge goes WAY past full when I fill it, and I am not yet sure where it runs out!
I don't care for the MPGs, but it may just be what it gets.  I do make up for the spending on gas though, since the parts for this truck are dirt cheap!
Offline FlatBlack77
« Reply #5 on: August 20, 2016, 01:05:44 pm »
how does the app work?
Offline big_al273
« Reply #6 on: August 20, 2016, 02:44:26 pm »
the most reliable way to figure out your MPG is the old fashioned way, next time you fill the truck up to full take note of your odometer reading then next time you fill the fuel take note of how many gallons you put in and the divide that number by the number of miles you've driven since the last fill up. My last tank got 96.2 miles and i put in 72 liters (19.02 Gallons) so when i divided 96.2 miles by 19.02 gallons i figured out that i got 5.05 MPG city
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline OldGray
  • Ne'er-do-well
« Reply #7 on: August 20, 2016, 05:33:22 pm »
Yep - that's exactly what the app does - only easier!   ;D
« Reply #8 on: August 21, 2016, 03:23:00 pm »
whats your timing at?
do you have smog equipment?
do you keep it uner 55?
do you take off easy?
Offline OldGray
  • Ne'er-do-well
« Reply #9 on: August 21, 2016, 06:15:06 pm »
whats your timing at? - 10dg BTDC
do you have smog equipment? - don't think so...?
do you keep it under 55?  - Who does?  Speed limit is 65, I do 65
do you take off easy? - somewhat, I am not a hot rodder anymore...
BTW - the tire size difference means I am actually getting around 12mpg.
Offline redhot1.4
« Reply #10 on: September 12, 2016, 06:43:20 pm »
My 350 3 speed
Running 285 75 r16 is best 11.3
I thought 305 was suppose to be better in mpg wise.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Offline OldGray
  • Ne'er-do-well
« Reply #11 on: September 12, 2016, 07:11:04 pm »
I have heard from a number of people that with a TH350 that I'd be luck to get good MPGs, so probably not gonna happen I guess!
« Reply #12 on: September 12, 2016, 07:48:26 pm »
Not sure why they'd say that----i got 18.85 mpg recently with a TH-350C.   Now, if you had a th-400..............
Offline redhot1.4
« Reply #13 on: September 13, 2016, 06:22:26 am »
I agree. I like to have an overdrive when I sold my daily driver. My Ole 78 bonanza became my new daily driver again. So I'd like to boost those mpgs a little more
Offline Flyinhillbilly
« Reply #14 on: September 16, 2016, 11:40:46 am »
I tune all my stuff with the innovate MTX-L. About $175 on fleabay, and you can dial them right to the numbers for maximum gas mileage at cruise, and max power at WOT. It makes it much easier when you can see your A/F ratio as a number in real time.
I was born on a mountian, raised in a cave,
Overpowered cars is all I crave.
