Author Topic: 1977 Chevy C60  (Read 8731 times)
Offline David A Young
  • New Guy
1977 Chevy C60
« on: August 20, 2016, 09:07:50 pm »
Ok guys I'm having a bit of trouble finding a part for my grain truck. The speedometer doesn't work. It has a 2 speed rear end and the reducer for the speedometer is locked up. I have dissassembled the reducer and cleaned it but it still doesn't spin. And the cable end is broken off inside (noticed that when I pulled it apart) it was just riding inside it. And I need a part # if anyone has one because every time I try to run the number i can't even get a pic of it to come up on Google. I have a gm service manual too and it shows a wiring diagram and nothing else. So if anyone has a number I wound appreciate it. Needing to get it going for harvest season. 1977 c60 350 ch465 2 speed rear. Thanks.
1985 GMC Sierra C1500 305HO/700R4/2.73 Open Diff
1986 Chevy K10 350/SM465/NP208/3.08 (will soon be 4.10 lol)
2 1985 Chevy parts K10s
Offline Stewart G Griffin
Re: 1977 Chevy C60
« Reply #1 on: August 21, 2016, 08:28:49 am »
If you're wanting to keep everything original i can understand.   But have you considered a GPS speedo?   Would be much simpler to get things running.
Offline FlatBlack77
Re: 1977 Chevy C60
« Reply #2 on: August 21, 2016, 05:38:26 pm »
or you could buy a cheap dash mount GPS.
on a side note i would like to see some pics of the truck i love the big old C60s
Offline big_al273
Re: 1977 Chevy C60
« Reply #3 on: August 21, 2016, 07:31:19 pm »
i'm going to suggest you go to your local heavy truck scrap yard and start looking there, even if you get a part number i don't think it will be easy to find a new unit
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
  • New Guy
1977 Chevy C60
« Reply #4 on: August 22, 2016, 10:56:54 am »
In response to some comments yes I'd like to keep it original, but I figured posting here would be a last resort thing. If I don't find a way to fix it I will run a cable directly to trans and it will just be off and I'll put up with it when I've got the rear end in low range. Ill try to post some pics either today or tomorrow. My schedule is kinda hectic right now with school and work and vehicles lol.
« Last Edit: August 22, 2016, 11:05:37 am by bd »
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 1977 Chevy C60
« Reply #5 on: August 22, 2016, 11:16:25 am »
Our reducer in our 69 C60 blew apart, and we couldn't find the right parts. But you may be able to try any big rig shop and see if they can find a substitute,  I know the older Macks ran a similar reducer with their split rear ends
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Online bd
Re: 1977 Chevy C60
« Reply #6 on: August 22, 2016, 11:18:08 am »
Agreed.  Many of the parts are obsolete.  Go to a local full-service speedometer shop that repairs medium truck speedometers.  They may still have the necessary pieces and be able to sort it out for you.
  • New Guy
Re: 1977 Chevy C60
« Reply #7 on: August 22, 2016, 11:47:05 am »
Ill try to snap some pics for the guys asking for pics. I think we might have a scrapyard around here that has two tons but I'm not sure. I figured most of them were obsolete but I figured I'd give it a shot. The truck is in really good shape and I'm wanting to fix it up but if I can't find the piece for the speedometer I'll more than likely end up putting a whole speedometer cable in it so that it will work. It would read right in high range then but be off in low.
Offline hatzie
Re: 1977 Chevy C60
« Reply #8 on: August 22, 2016, 05:00:28 pm »
The MD and the LD share speedometer cable parts.
New Ratio boxes and Speedometer cables and attaching parts are available from PATC Transmissions.  You'll need to call them to determine what you have and what you'll need.
https://transmissioncenter.net/shop/ratio-adapter-other-ratios-available-call-jim-1-888-2012066/
  • New Guy
Re: 1977 Chevy C60
« Reply #9 on: August 22, 2016, 07:39:38 pm »
This unit runs on 12V if they are electric then they may have what I need.
