Author Topic: floor panels rusting out...  (Read 5670 times)
Offline 81ShotTCheV
« on: May 20, 2006, 12:03:00 am »
i have an 81 short wide and the floor panels r really rusting out.. my question is how hard r these to change...and r there any tutorials on this topic.....thanks david
Offline 123 pugsy
Re: floor panels rusting out...
« Reply #1 on: May 20, 2006, 06:51:00 am »
Are the rockers and cab corners also rusted? You'll need to cut away all the rusted metal to the point of where you have something solid to weld/screw/rivet to. How are the cab supports?
Click on the link to see some photos of a patch I did.It's a little extreme ,but you can get some idea.
s45.photobucket.com/albums/f81/123pugsy/?start=20
Pugsy
76 C10 LWB
TPI 350
Offline 81ShotTCheV
« Reply #2 on: May 20, 2006, 11:44:00 am »
the cab corners r fine but i figure i should go ahead and do it all so i have that piece of mind and i have the cab off the frame....the supports have no rust visible to me.....but the pics helped alot...i will just get the floor panels from this website....but yeah thanks pugsy
« Reply #3 on: May 21, 2006, 08:45:00 am »
Put the sand blaster to it yuo might be suprised at the rust you don't have.
