Author Topic: oil pressure gauge  (Read 6885 times)
Offline cwilson jr
oil pressure gauge
« on: August 23, 2016, 06:23:05 pm »
I've had issues with the oil pressure gauge in my 85 k10 for as far as I can remember.  It used to work sometimes IF i recall correctly, but hasn't read anything at all in quite some time.  Where could i start looking?  I don't really want to tear my cluster off,  plus I'm thinking the issue is probably with the switch, or line, or whatever these trucks have, because all of my previous gauge issues in the past have been and want to tear it out, last.
Offline hatzie
Re: oil pressure gauge
« Reply #1 on: August 24, 2016, 05:57:05 pm »
0psi nothing or nailed nothing?
Sent from my SM-P605V using Tapatalk
Offline cwilson jr
« Reply #2 on: August 29, 2016, 07:14:50 am »
it just reads 0 on the gauge.  i dont believe its stuck.
« Reply #3 on: August 29, 2016, 10:55:04 am »
What happens when you unplug the wire from the oil sender?
Offline OldGray
  • Ne'er-do-well
« Reply #4 on: September 07, 2016, 12:31:47 pm »
A few days ago I pulled off the dash trim, and then the clear gauge covering.  After that removing the gauges is pretty simple.  Once you remove the bolts they just slip right out - no wires, just "plug in" to the dash.
I cleaned all the contacts on gauges and dash, added some electric grease (and replaced the burned out dash bulbs while at it).  To my surprise, my oil and volt meter both started working properly, AND my gas gauge no longer goes WAY past full but to where it should go.
Maybe a 2-3 hour job and well worth trying.
1979 Chevrolet Bonanza / 305 / LWB
