Author Topic: Globe box problem  (Read 5827 times)
Offline philo_beddoe
  • 77 C-10
Globe box problem
« on: August 26, 2016, 08:37:20 pm »
I bet this is a common problem with our glove boxes, the lower strip is coming off where it attaches. Any solutions?
Offline Rattler12
  • Old Geezer
Re: Globe box problem
« Reply #1 on: August 26, 2016, 09:35:29 pm »
Couple of layers of black gorilla tape worked on mine
83 C-10 shorty 454, 5spd, 3:73 posi
Offline LTZ C20
« Reply #2 on: August 26, 2016, 10:41:37 pm »
New glove box door is the only proper solution.
LTZ Cheyenne C20
  • 77 C-10
Globe box problem
« Reply #3 on: August 27, 2016, 09:08:41 am »
GM should have made that a real hinge. A shame to have to replace the oem glove box over that.
« Reply #4 on: August 27, 2016, 10:11:21 am »
You find a replacement and put your metal cover on it.  I found that the newer the better used.  I have found that the non-AC are next to impossible to find.  I have also seen a piano hinge work but not as nice as the original
Offline Militiaman55
  • 74 K10 Cheyenne
« Reply #5 on: August 27, 2016, 11:44:56 pm »
I used an aftermarket replacement and it's been great for many years.  Only problem is I lost my original, with RPO codes during a move... Still kicking myself.
« Last Edit: August 28, 2016, 01:34:12 pm by bd »
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #6 on: August 28, 2016, 08:42:17 am »
I am in the process of installing and fabricating the right stuff to put a piano hinge on the glove box so i can keep the original.  :)
  • 77 C-10
« Reply #7 on: August 28, 2016, 01:19:02 pm »
I may delve into that, black gorilla tape first.
