Author Topic: Driver side wheel noise help  (Read 4462 times)
Offline Als87
« on: August 30, 2016, 12:10:34 pm »
I have an occasional grinding coming from somewhere close to my front driver's side wheel. It is a 4wd truck. I've not used my 4wd in the past couple weeks so it does it in 2wd. It had new bearings about 6 months ago. It doesn't do it at a certain speed or when I hit the brakes, it's just random. It does it for a few min sometimes, other times just for a few seconds but it's a pretty rough sounding grinding or rubbing noise. Any ideas? Bushings? U joints? Thanks
'87 Shortbed 4x4
350, 350thd
4" suspension lift on 35's
Re: Driver side wheel noise help
« Reply #1 on: August 31, 2016, 03:10:51 pm »
maybe the bearing??? due to improper install, its a guessing game right now. but bushings shouldnt grind and u joints shouldnt if youre not in 4wd up front at least
Offline Als87
« Reply #2 on: September 01, 2016, 08:35:03 am »
Ok I'm going to double check the bearings this weekend then
'87 Shortbed 4x4
350, 350thd
