Author Topic: Best rust converter?  (Read 22628 times)
Offline IUFAN87
« on: March 20, 2006, 04:26:00 pm »
I've got some surface rust areas on my 85 Silverado. I am sanding all the rust off that I can. Problem is some of the areas are pitted. What is the best rust converter to use before I paint? I have used por-15 before but didn't have the vehicle long enough to know how long it lasted. I searched and found a product called rust bullet thats supposed to be better than por-15. I've also used the permatex brand in the spray bomb. Anybody know what'd be the best and most economical? I just don't want the rust to come back right after I fix it. Thanks:)
Re: Best rust converter?
« Reply #1 on: March 20, 2006, 10:05:00 pm »
I would say POR 15 is your best bet. You need to top coat it right away though.
Edited by: Blazin at: 3/22/06 8:35 am
ccb
  • Guest
« Reply #2 on: March 20, 2006, 09:41:00 pm »
I did a search on that once and there are some product one you can get at Home Depot. The other two are on the internet just do a rust remover search.
Craig
Offline 123 pugsy
« Reply #3 on: March 21, 2006, 04:06:00 am »
Up here in the eskimo land,I use Rust Check (rattle can) to turn the rust into black oxide.Then sand most of it off,leaving it in the pits.Use a nice epoxy primer over that.  My 2 cents.
Always follow your gut instincts and pick something you think sounds reasonable.I would do as Craig said and search for rust removers and rust convertors.
Pugsy
76 C10 LWB
TPI 350
« Reply #4 on: March 21, 2006, 06:50:00 am »
Permatex has one called Extend that I have used. It too coverts the rust to iron oxide. It seemed to work well, I used it on a dimond plate flat bed. I top coated it with acrylic enamal and it held up well.
Edited by: Blazin at: 3/21/06 6:51 am
Offline roundedline
« Reply #5 on: March 21, 2006, 10:19:00 am »
I have had good results with POR15, and friends have used Rust Mort.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline DainBramaged
POR-15
« Reply #6 on: March 29, 2006, 10:49:00 am »
When I did my frame off I used POR-15.  That stuff is great!:D
Offline maxwell75c10
POR-15
« Reply #7 on: May 23, 2006, 08:53:00 am »
with my experinces   rust is there to stay no mater what.
the best rust removal (for bodies any way) is always new metal!
Offline NHRADRAGRACER
Rust remover
« Reply #8 on: June 14, 2006, 05:31:00 pm »
To remove rust and restore try safest rust remover. This stuff is great.
www.safestrustremover.com/
Edited by: NHRADRAGRACER at: 6/14/06 4:35 pm
Offline DnStClr
Re: Rust remover
« Reply #9 on: June 16, 2006, 04:47:00 pm »
whoa man! That's pretty impressive stuff.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
