Author Topic: 86 Chevy Suburban 3\4 ton  (Read 3536 times)
Offline daddio0545
« on: September 05, 2016, 12:19:46 am »
Headlight problem when the lights are on high beam they all work when on low beam no lights other wise lower beams aren't working - could this be headlight dimmer switch problem ???
Thanks for your input
Re: 86 Chevy Suburban 3\4 ton
« Reply #1 on: September 05, 2016, 07:43:32 pm »
what headlight do you have?
Offline daddio0545
« Reply #2 on: September 06, 2016, 11:31:14 pm »
It was the drivers side headlight conicter to
Offline daddio0545
« Reply #3 on: September 06, 2016, 11:35:26 pm »
It was a simple fix headlight connector on the drivers side - thanks for your reply
