Author Topic: Back flush system - never got hot  (Read 4358 times)
Offline My85Chevy
    • Cabs Classics
« on: September 12, 2016, 06:14:18 pm »
Hey guys,
I know a cool running truck is ALWAYS better than hot one, but my 85 needle barely moves off the 100 mark.  I back flushed the system through a tee that was installed by the previous owner today.  Even after 10 minutes and the heater on high the water coming from the radiator spout I installed was luke warm at best.  The heat in the cabin is excellent.  Thermostat not opening?  Not sure what direction to go, or if I should do anything at all!
Thanks
Alan
Re: Back flush system - never got hot
« Reply #1 on: September 12, 2016, 10:05:39 pm »
if you never get hot it might be cause of no thermostat or its stuck open. if the heat in the cab is good then i would be thinking more like a bad gauge or sending unit
Offline My85Chevy
    • Cabs Classics
« Reply #2 on: September 12, 2016, 11:01:23 pm »
Thanks.  Yes I was thinking if it was stuck open I wouldn't be getting the heat in the cab.  I'm just going to open it up and see what I have in there.  I have a new stat I'll put in regardless.  180 degree.  What sending unit would you be talking about?    I think the gauge is fine, it seemed to agree with the temp of the water coming out... not hot!
Offline My85Chevy
    • Cabs Classics
« Reply #3 on: September 13, 2016, 09:48:53 am »
Hey forget that, I know now your talking about the temperature sending unit.  It's a 10 buck part so I'm going to go ahead and replace it and the thermostat and see what the result is.  Thank you!
« Reply #4 on: September 13, 2016, 12:10:58 pm »
you can test those parts before you buy new. if you run it for a while can you hold the bottom hose is the temp really different between the top and bottom?
Offline My85Chevy
    • Cabs Classics
« Reply #6 on: September 13, 2016, 06:38:32 pm »
The upper and lower hoses felt exactly the same.
The heater hoses on this truck look really bad and about to burst.  Plus I would like to get this tee someone put in before me out.    shows a 5/8 inch to engine and a 3/4 inch to radiator.   Can you guys verify two different sized heater hoses?  They sure look the same to me!
Thanks and thanks for the links to the tests!
« Reply #7 on: September 13, 2016, 07:22:42 pm »
5/8" hose runs from the coolant crossover next to the thermostat into the heater core, 3/4" hose runs from the heater core out to the radiator (or water pump depending on year and configuration).
