Author Topic: Like hicups ?  (Read 6278 times)
Offline Tazman
Like hicups ?
« on: September 12, 2016, 07:17:29 pm »
Coming home from work on the freeway with light traffic backlogs and going about 25 to 30 mile per hour. When giving it just a little gas it stumbled or kind of like hiccupped. No check engine light came on yet it did this about a dozen times but only when going between 25 to 35 mph, when going faster it worked great. When making a turn and getting up to speed it worked great. I know this can sound like fuel pressure yet I do not understand that if it is then why does it not do it all the time?
Thanks,
God BLESS AMERICA
Re: Like hicups ?
« Reply #1 on: September 12, 2016, 07:50:37 pm »
It may be a plug wire breaking down, light load on a low rpm are a booger to track down sometimes.  Minor vacuum leak/lean miss is another possibility
Re: Like hicups ?
« Reply #2 on: September 12, 2016, 08:07:57 pm »
I agree.  A bad wire, worn or cracked spark plug, perforating coil or rotor, carbon tracking in the cap - virtually any breakdown in the ignition secondary circuit can cause this.
Offline Stewart G Griffin
Re: Like hicups ?
« Reply #3 on: September 12, 2016, 09:52:07 pm »
Also check both battery cables for tightness and condition.
