Author Topic: Voltmeter  (Read 4154 times)
Offline My85Chevy
    • Cabs Classics
Voltmeter
« on: September 13, 2016, 09:51:26 am »
This gauge has never worked since I bought my 85 C10.  Is there anything to possibly look at other than a bad gauge before replacing it?
« Last Edit: September 13, 2016, 06:42:33 pm by My85Chevy »
Offline LTZ C20
Re: Ammeter
« Reply #1 on: September 13, 2016, 09:54:09 am »
If it's an 85 it should have a volt gauge not an ammeter. If it has an ammeter someone has swapped it in.
LTZ Cheyenne C20
Offline My85Chevy
    • Cabs Classics
Re: Ammeter
« Reply #2 on: September 13, 2016, 06:32:18 pm »
You are correct.  It's a voltmeter.  It's always been pegged to the left.  Never moved.
« Last Edit: September 13, 2016, 06:56:57 pm by bd »
Re: Voltmeter
« Reply #3 on: September 13, 2016, 07:06:49 pm »
Check the fuses.  Check for ignition power and ground to the PC board and through the spring clip connections that connect the PC board to the voltmeter pins.  Oxidation of PC board connections and loss of spring tension on gauge pins are common problems.  If the PC board is tarnished, gently polish the copper foil with a soft rubber eraser or crocus cloth.  Be careful not to peel the foil loose from its plastic backing.  If you confirm ignition power and ground at the voltmeter pins, the voltmeter is faulty.
