Author Topic: Replace steering dampner  (Read 6650 times)
Offline justinwilkie4
« on: September 14, 2016, 05:01:40 pm »
Hey guys, new to the forum. My old truck was an 06 TBSS. Anyhow my grandpa passed down my 87 K10/R10. I'm in the process of slowly restoring and fixing everything and I'm trying to replace the steering dampner before I replace the steering gear. I've got one side off but the second side is seized up. It's got one nut on the outside that I got off, and then it's got one nut on the other side. I can't get the bolt to move and I've soaked it with PB blaster. Do I need to get the other nut loose before I can take it all out? And secondly the new one I bought only has 1 nut. Just looking for advice thanks
Sent from my SM-N920V using Tapatalk
Re: Replace steering dampner
« Reply #1 on: September 14, 2016, 06:11:07 pm »
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: September 15, 2016, 04:27:50 am »
Unfortunately you will probably destroy that bolt getting it out, so make sure you can get another. I flip the castle nut and start it on the threads, gives better surface area and just start whacking away with a hammer. That bolt has a tapered shaft, which makes it hard to remove, very rarely do I manage to save the bolt, no matter how I try.
 1986 Chevy K30(under repair)
« Reply #3 on: September 15, 2016, 10:42:41 am »
One of the following pullers should work.  Just measure the tie rod and choose the tool that fits:  OTC Pitman Arm Puller/Tie Rod End Puller 6296, OEM Specialty Tools 25297, SPC Performance 5 in. Tie Rod Puller 8370.
Offline Peter S
« Reply #4 on: September 15, 2016, 12:18:06 pm »
The bolt in question is part of the steering damper that you are replacing. The new damper comes with a new bolt. Just beat on the old one until it pops.
-Peter
1978 K10 stepside
« Reply #5 on: September 17, 2016, 06:52:37 pm »
Alright, so just beat the shoot out of it?
Offline Captain Swampy
  • Wisconsin
« Reply #6 on: September 20, 2016, 10:08:05 pm »
You could put the nut on loose and lock it with a new cotter pin, then drive it until it pops loose. Otherwise buy a tool, or beat the poop out of it. If you choose the latter, you'll be beating up your tie rod end also.
