Author Topic: removing rear window slider help needed  (Read 5766 times)
Offline 80stepsideguy
« on: July 02, 2006, 08:09:00 pm »
I am in need of some assistance on how to remove a rear window slider w/o destroying it.I am going to be cutting the roof off my 80 and its going to the J/Y in about a week or so so i need some help on the proper way to remove it ..
thanks
pat
1998 Chevy 1500 S/B 2wd
gpday06
  • Guest
Re: removing rear window slider help needed
« Reply #1 on: July 03, 2006, 11:25:00 am »
all the ways ive seen it done by the pros is just to go inside and give it a good push! of course have someone catch it, and if you need more power then lay on the seat and use your legs
« Reply #2 on: July 03, 2006, 02:36:00 pm »
I took your advise but i used a couple of long flathead screwdrivers and took my time and it popped right out so i can now cut the roof off since i got the windshield out as well..
thanks for replying
pat
gpday06
  • Guest
« Reply #3 on: July 03, 2006, 04:38:00 pm »
its no problem, i know i appreciate it when others help me
