Author Topic: Dash bezel id  (Read 7266 times)
Offline noclrnce
Dash bezel id
« on: September 25, 2016, 07:14:10 pm »
Can anyone tell me what year this bezel is supposed to be from? My truck is an 83 and it just doesn't fit right. Note the corners.
Re: Dash bezel id
« Reply #1 on: September 25, 2016, 08:51:17 pm »
1981-1983 AC from the looks of it.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Dash bezel id
« Reply #2 on: September 26, 2016, 05:04:14 am »
Agreed, is it possible the dash pad is aftermarket? That's the most common part to be screwed up in one way or another.
 1986 Chevy K30(under repair)
Offline noclrnce
Re: Dash bezel id
« Reply #3 on: September 26, 2016, 09:13:22 am »
I honestly can't tell on the pad. I bought the bezel from a guy on Craigslist. I am also noticing the bezel doesn't sit all the way up against the gauges like my 87 does. It's also very hard to see the gauges. I can fit my finger between the gauge and the bezel. Are all the bezels interchangeable?
Offline Ludwig Von 88
  • Mad world.
Re: Dash bezel id
« Reply #4 on: September 26, 2016, 10:17:07 am »
your holes seems to not be on the right place, especially the one on the top left. I just change mine 2 weeks ago, it's an after market and it fit very well. There is some little differences with the year of your truck, but nothing what can realy not fit, just a little job to do. I send you the link where i buy mine, cause it' explaining the years where you have little troubles. Mine is a 1980 but i think it can maybe help you.
http://www.ebay.com/itm/73-80-chevy-GMC-NEW-pickup-truck-dash-bezel-gauge-cluster-cover-brushed-aluminum-/122070318102?hash=item1c6bf53c16:g:kmYAAOSw2GlXJ2so&vxp=mtr
Ludwig Von 88
1980 Chevy Suburban C20 3/4 ton Scottsdale.
Offline noclrnce
Re: Dash bezel id
« Reply #5 on: September 26, 2016, 10:13:42 pm »
Do you think I may have the wrong bezel?
Re: Dash bezel id
« Reply #6 on: September 26, 2016, 11:11:50 pm »
Yes because your truck doesn't have AC but it is correct for 81-83.  Your dash pad is off or the instrument cluster has broken tabs not holding the dash up far enough.  That upper left hole just used the dash pad to screw into if I am remembering correctly.
Offline noclrnce
Re: Dash bezel id
« Reply #7 on: September 30, 2016, 09:25:00 am »
This is my 87 and it fits much better
