Author Topic: Fuel Gauge Question  (Read 5426 times)
Offline Jon87V20
Fuel Gauge Question
« on: October 03, 2016, 08:00:42 pm »
Hello!
I have an '87 Suburban V20 that did not come with the factory-equipped tach. It's also a single fuel tank truck if that matters.
I'm wondering if anyone knows if the large fuel gauge that came with non-tachometer equipped trucks can use the same sending unit as the smaller fuel gauge that came with the tachometer-equipped trucks. Are they calibrated the same? Could I just plug and play a smaller fuel gauge with the same wiring as the large one, or would this read wrong?
I'm asking because I was considering putting an Autometer tach I have in the fuel gauge spot next to the speedo and moving to a smaller fuel gauge in the lower left unused spot by the other gauges.
Thanks!
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: Fuel Gauge Question
« Reply #1 on: October 03, 2016, 08:58:37 pm »
Senders are electrically the same, 0 - 90 Ohms.  There is a difference in physical configuration, because of the in-tank fuel pump, but that should have no bearing on what you are doing.
« Last Edit: October 03, 2016, 09:01:25 pm by bd »
Offline Jon87V20
« Reply #2 on: October 04, 2016, 09:47:03 am »
Ok, great to know. Thanks, bd!
