Author Topic: build suggestion  (Read 7080 times)
Offline Macaroni_Sackaroni
build suggestion
« on: October 05, 2016, 09:57:13 pm »
ive been planning my build since i bought the car, saving up decent money for this project. Not looking to a build a real performance muscle truck or anything crazy, just looking to a have a good running truck with a bada** sound. looking for suggestions and critical opinions.
budget:
$3000
motor:
l98 tpi 5.7l from a firebrid ecu
i think tranny is a  th400
12bolt diff not sure what gear ratio
current plans so far:
first see if the block is good.
have block honed by friend
throttle body + camshaft (thinking this may not be necessary)
headers (maybe just headers after i get it honed)
good professional tune
possibly straight pipes.
« Last Edit: October 05, 2016, 10:00:13 pm by Macaroni_Sackaroni »
Offline Stewart G Griffin
Re: build suggestion
« Reply #1 on: October 09, 2016, 07:40:39 am »
Is the engine in the truck?
« Reply #2 on: October 09, 2016, 03:02:20 pm »
yup wire up with an ecu runs. smokes sometimes thinking the head gask has a little leak.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #3 on: October 09, 2016, 04:02:48 pm »
Smoking sometimes could be the valve seals or piston rings....or even a fuel build-up.
« Reply #4 on: October 10, 2016, 07:24:55 pm »
the reason i think its gask because everytime i run it it shoots a little water out and smells sweet like coolant. but... smoke goes away after driving it for a little so makes me think its just extra moisture because i run it like every about 2-3 weeks just around the neighborhood. not sure its that though because its garaged.
ill find out when i eventually take the motor out.
« Reply #5 on: October 12, 2016, 10:19:51 pm »
if the smoke is white and clears up more than likely its just moisture in the air or muffler. if it continues to smoke thats when you should worry or if youre losing antifreeze
