Author Topic: swap questions  (Read 11587 times)
gpday06
  • Guest
swap questions
« on: August 05, 2006, 04:07:00 pm »
im about to buy an '85 C20 for doors for my '79C10, the question is what else will fit onto my truck? i.e. fenders, hood, glass? thankx for the help
Offline 123 pugsy
Re: swap questions
« Reply #1 on: August 05, 2006, 05:04:00 pm »
I believe everything can swap except the rear springs unless you moved the spring perches.
Pugsy
76 C10 LWB
TPI 350
gpday06
  • Guest
Re: swap questions
« Reply #2 on: August 06, 2006, 12:53:00 am »
also what about the beds?
Offline 123 pugsy
Re: swap questions
« Reply #3 on: August 06, 2006, 01:50:00 pm »
No problem.
On my 76 C-10,I have a 79 C-20 frame,a 76 cab,an 81-87 box (not sure of the year exactly). I also have an 87 tilt steering colunm,700 r4 tranny and A/C system. I have 81-87 doors installed as well.
Edited by: 123 pugsy at: 8/6/06 12:55 pm
Pugsy
76 C10 LWB
TPI 350
Offline lowc10
Re: swap questions
« Reply #4 on: August 06, 2006, 01:13:00 pm »
everything should swap but the front end, you can swap the whole front end but not parts of it
Offline shaved80
Re: swap questions
« Reply #5 on: August 09, 2006, 12:39:00 pm »
you sound like me 123 pugsy, i have an '80 cab, 73-78 front end, 91 burban doors (or so i was told..) and an 81+ bed!
Edited by: shaved80 at: 8/9/06 11:40 am
Offline roundedline
Re: swap questions
« Reply #6 on: August 09, 2006, 05:11:00 pm »
The one I am building that is documented on the forum has the following:
1991 grille pieces
1981-1987 style frontend (fiberglass)
1982 cowl panel
1986 cab
1983 door
1986 door
1980 Bed
1973 frame
1981 front bumper
1989 Blazer tank
1977 seat
1989 dash
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 123 pugsy
Re: swap questions
« Reply #7 on: August 09, 2006, 06:25:00 pm »
Ya,these trucks are great for mix and matching.:smokin
Pugsy
76 C10 LWB
TPI 350
Offline lowc10
Re: swap questions
« Reply #8 on: August 09, 2006, 07:21:00 pm »
reminds me of johnny cash's one peice at a time. What company is the fiberglass front end from? Good stuff or did it need some work?
Offline roundedline
Re: swap questions
« Reply #9 on: August 09, 2006, 10:17:00 pm »
USBody makes the tilt I have.  Excellent quality.  My other truck will be getting one from them also.
Project Su
Jimmy 2WD Project
Offline lowc10
Re: swap questions
« Reply #10 on: August 09, 2006, 10:26:00 pm »
I was looking at just fenders and a hood from there or unlimited products.
Offline roundedline
Re: swap questions
« Reply #11 on: August 09, 2006, 10:28:00 pm »
Unlimited Products parts are good only if you plan to drag race and not show it or not expect it to look good.  Personally, I would avoid them like the plague.
Project Su
Jimmy 2WD Project
Offline lowc10
Re: swap questions
« Reply #12 on: August 09, 2006, 10:30:00 pm »
It wont be show qaulity but I for sure want it to look good. Thanks for the heads up on them.
gpday06
  • Guest
Re: swap questions
« Reply #13 on: August 10, 2006, 01:00:00 pm »
if i take the doors that are electric and put them into my truck thats not electric,what exactly needs to be done, oh and its electric locks and windows
Offline roundedline
Re: swap questions
« Reply #14 on: August 10, 2006, 06:07:00 pm »
You need the harness from the doors to the inside of the truck.  It is seperate from the rest of the harness.
Project Su
Jimmy 2WD Project
