Author Topic: High Beams just stopped working  (Read 4184 times)
Offline boulky12
  • Dallas, TX Daily Driver
« on: October 15, 2016, 06:26:45 pm »
Hey guys. My High beams just randomly stopped working one morning.
I checked for voltage at the green high beam wire on the headlights. It was very little to none. It was fluctuating between .03 to .08.
I cleaned the 2 grounds on the core support for the headlights, with no change. But I don't think its a ground issue because there was never any flickering. They just stopped working.
I noticed I can now turn my low beams on/off by pulling back on the high beam switch. That didn't used to happen.
I also noticed the 2 blue dots in my gauge that would indicate the high beams were on, are now gone.
I don't know if this would have anything to do with it but I always used my high and low beams. Any time my headlights were on, my high beams were on.
My truck is an 86 with the 4 Headlights.
Whats do yall think is going on here?
Thank you
86 Swb GMC, 2/2 drop, stock 305/350, Quadrajet, Dual Tanks, 3.08 gears, Rally wheels
Re: High Beams just stopped working
« Reply #1 on: October 15, 2016, 07:44:28 pm »
Probably a bad dimmer switch.
Offline boulky12
« Reply #2 on: October 15, 2016, 08:06:38 pm »
Alright I'll pick up a new dimmer switch one of these days.
Thanks
Offline square81
« Reply #3 on: October 19, 2016, 07:38:03 pm »
Had the same issue with my truck. Replaced the dimmer switch. Worked good.
Offline boulky12
« Reply #4 on: November 04, 2016, 03:44:23 pm »
Yup dimmer switch was the fix. Now all 4 headlights work again.
I was able to replace it without dropping the column. It was a big pain in the butt, but it is possible.
