Author Topic: 1987 R10 Silverado 2wd  (Read 40691 times)
Offline justin71105
Re: 1987 R10 Silverado 2wd
« Reply #15 on: November 01, 2016, 06:43:42 pm »
Here is a picture of the part the lines connect to, I will try to trace them down tomorrow in the daylight or next week when I get off work.  Hopefully I can get up tomorrow evening before work and trace it down and get it ordered so I can replace it next week when I get off work.
1964 C10
Offline bd
« Reply #16 on: November 01, 2016, 07:23:17 pm »
Those are brake lines connected to the brake combination valve.  Are you sure the fluid leak is from the valve or its lines?  That fluid color looks more like power steering fluid than brake fluid.  What color is the fluid in the brake master cylinder?  Check the front pump seal, the reservoir and the hoses for a power steering fluid leak.
Offline justin71105
« Reply #17 on: November 01, 2016, 07:27:05 pm »
Yea it is red fluid and the PS is what I have had to fill the past two days, I just noticed the cap is busted on the corner and I can pull up on it and pop the cap off without unscrewing it.  I washed all the parts that had the fluid on them down tonight and will try to pick up a new cap before driving it and see if that is the problem.
-- After installing the new ignition coil today the truck runs very good, hoping its just the cap and I can start working on the rest of the problem areas and start driving it around for errands.  I set the idle with the IAC on it but have one coming from rock auto as well, it was idled about a 1/8 turn low going from my ears and listening how it would run.....don't have an rpm gauge.  I idled it in Park just where it would idle and not die, if I turn the idle screw back maybe an 1/8 it would start to bog down a little and want to die.
« Last Edit: November 01, 2016, 07:32:08 pm by justin71105 »
1964 C10
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #18 on: November 01, 2016, 07:57:36 pm »
I bet one of the rubber lines for the steering(most likely pressure side) has developed a pinhole leak, and it just happens to be hitting the brake combination valve. The cap may have a little fluid push past it, but nothing like what you are saying.
 1986 Chevy K30(under repair)
Offline justin71105
« Reply #19 on: November 01, 2016, 08:05:33 pm »
I can swap that out next week as precaution too, its also cheap.
1964 C10
Offline justin71105
« Reply #20 on: November 02, 2016, 06:35:01 pm »
I finally got some help from my brother on checking the lines today, had him move wheels one side to the other and you were correct when he got to the farthest amount of travel there was a pin hole shooting fluid from the pressure line.
Changed it out today and the leak seems to have gone away, the line they had on there was badly bent at the pump as well.  I thought I had gotten the wrong line until I saw that the last one to install it had bent the line into a box shape instead of how it comes in a U shape.
New IAC Valve came in today from Rock Auto, got it put on and reset.  Going to get a polishing wheel from harbor freight next week and try to get these factory wheels polished up and see if I want to keep them or look for some 18's or 20's instead of the 22's.  Prefer a wheel like the American Racing Nova Chrome or something similar, just need to find out what size and backspacing I can run with a 2-3" drop spindle.
1964 C10
Offline justin71105
« Reply #21 on: November 11, 2016, 01:35:10 pm »
New headliner installed today, we have an auto upholstery store here local and I picked up 10 yards of house brand headliner material and 2 cans of adhesive spray for $70. Was cheaper to buy 10 yards of house material than buy the name brand by the yard for the 3.5 yards I wanted.  Tomorrow I plan to pull the dash out and attempt to repair the cracks and spray paint it black with the krylon fusion paint.  Have had really good results with it on motorcycle fairings.
1964 C10
Offline justin71105
« Reply #22 on: November 13, 2016, 05:37:17 pm »
Ordered my lowering kit, 2.5" spindles and shackles/hangers for 4" drop in rear.  Ordered new brake lines to bend around the new spindles and new brake pads.  The caliper and rotors have some rust on them as well, so I may pick those up when all my other parts get here.  Or hit them with a wire wheel and spray with high temp black spray paint.
Seems they have already been upgraded to the 1.25" rotors as well.
Sent from my SAMSUNG-SM-G850A using Tapatalk
« Last Edit: November 13, 2016, 05:44:04 pm by justin71105 »
1964 C10
Offline bd
« Reply #23 on: November 13, 2016, 07:17:28 pm »
FYI - The top front steering gearbox mounting bolt is missing (upper right corner of image).  Replace the missing bolt and check the others.
Offline justin71105
« Reply #24 on: November 13, 2016, 07:31:43 pm »
Thanks for the heads up, will check them out tomorrow and get the missing bolts replaced.
1964 C10
« Reply #25 on: November 13, 2016, 08:47:16 pm »
Good eye on the missing bolt, I have seen some people get a 1/2" longer bolt and put a locknut on the end for more security.
FYI torque for bolts is around 60 to 80 ft-lbs depending on which manual you read.
Offline justin71105
« Reply #26 on: November 14, 2016, 08:13:51 am »
RPO codes still in glove box, trying to decode them now:  Some may be incorrect as I am getting the info from online sources.
AU3- Power door locks
A01- Tinted Glass
A28- Sliding Rear Window
A31- Power Windows
A52- Front Bench Seat
BB5- ORNAMENTATION, INTR, HEADLINER
BC3- ORNAMENTATION, INTR, I/P, DELUXE
BS4- INSULATION, BACK PNL
BX6- ORNAMENTATION, EXTR MLDG, APLQ, CAB BACK PNL
B30- COVERING, FLOOR CARPET
B32- Color Keyed Front Floor Mats
B7P- BODY EQUIPMENT, PICKUP BOX PANELS (PRIME)
B85- Bright Body Side Moldings
F59- Front Stabilizer Bar
GU4- AXLE REAR, 3.08 RATIO
G50- SPRING REAR, HEAVY DUTY, VAR 1
G80- AXLE POSITRACTION, LIMITED SLIP
JB5- BRAKE SYSTEM,VACUUM POWER DISC/DRUM
J55- BRAKE SYSTEM,VAC PWR
K22- 94 Amp Alternator
K34- ELECTRONIC SPEED CONTROL (CRUISE CONTROL)
L03- ENGINE, 305 C.I.D. V8 (305H) - TBI
MD8- TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0- MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5- EMISSION SYSTEM, FEDERAL, TIER O
NL2- Auxiliary Fuel Tank (pick ups)
U76- Windshield Antenna
V22- Chrome grille
V73-  VEHICLE STATEMENT, USA/CANADA
XFN-
YA8-
YE9- CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3
YFN-
YG3- ORNAMENTATION, BODY, SIDE, 6 WHL OPENING BRIGHT
YH3-
ZFN-
ZN3-
ZQ2- SALES PACKAGE, DRIVER CONVENIENCE
ZY1- COLOR COMBINATION, SOLID
Z53- CLUSTER, INST, OIL, COOL, TEMP, VOLTS
18D- TRIM COMBINATION, CLOTH, DK CHARCOAL (D)
18I- INTERIOR TRIM, DK CHARCOAL (I) (91)
19U- PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
« Last Edit: November 14, 2016, 08:54:49 am by justin71105 »
1964 C10
Offline bd
« Reply #27 on: November 14, 2016, 09:27:46 am »
Perhaps RPO Codes in our Technical Pages will help.
Steering gearbox mounting bolt torque is 75 ft-lbs (1987 Factory Service Manual).
Offline justin71105
« Reply #28 on: November 17, 2016, 01:03:27 am »
Thanks I got one more code from that sheet still haven't been able to locate the rest.  I was missing the on bolt on the gear box and another one on a  bracket that goes to the front bumper.
After I get my lowering kit installed, I am probably going to order the jegs longtube headers and have a new exhaust welded on it.
Wanting to gave these 3.08 gears swapped out for something like a 3.73 for some more low end go.
« Last Edit: November 17, 2016, 03:35:59 am by justin71105 »
1964 C10
Offline justin71105
« Reply #29 on: November 18, 2016, 04:16:08 pm »
Time to get a little Low, 2.5/4 lowering kit.  Have new brake lines and pads, I was going to order upper and lower control arms but Rock auto does not list lower control arms only uppers.  Would like to find a set rather than pressing out the ball joints and bushings.....but looks like I may be rebuilding the ones in it, the lowers atleast can't find them anywhere.
Will also go ahead and replace inner/outer tie rod ends and sleeves, pitman and idler arm while I am in there I guess.
 Climbed back under the truck before I headed to work and all the rubber boots are in pretty bad shape after all and have dirt under them it looks like.
« Last Edit: November 19, 2016, 01:23:19 am by justin71105 »
1964 C10
