Author Topic: Craigslist Wheels Fitment Check  (Read 9087 times)
Offline harcorshe
« on: October 21, 2016, 11:36:56 pm »
This are from a 2004. They will fit my '78 K20, yes?
https://denver.craigslist.org/pts/5832189610.html
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Re: Craigslist Wheels Fitment Check
« Reply #1 on: October 22, 2016, 07:16:44 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32604.0
this is a sticky on the top of the "tires/wheels"
that being said gm didnt change the 8 lug till 2011 where they went to metric for better gvwr
Offline LTZ C20
« Reply #2 on: October 22, 2016, 11:49:31 pm »
Not true, they went to metric thread studs in the early 2000's. My new 02 has metric studs. The 8 lug stud pattern diameter stayed the same from 60 or 70 something all the way up to 2010, 2011 the stud pattern diameter was made larger to increase GVWR and payload/heavy duty abilities. So if they are 2011 or newer, then no they will not fit and you will need an adapter but I'm not sure there is an adapter as there isn't a substantial difference in stud pattern diameter. If they are 2010 or older then yes they should fit.
I put 8 lug wheels from an 08 3/4 ton on my 3/4 ton square with no adapters of any kind, perfect fit, and then swapped the same wheels onto my new 02 3/4 ton, still a perfect fit.
Also those wheels you posted are 17 inch diameter.
LTZ Cheyenne C20
« Reply #3 on: October 23, 2016, 01:54:43 am »
not the threads but the bolt pattern 8x6.5 to 8x180
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: October 23, 2016, 06:04:12 am »
Correct, metric threaded studs themselves came out in '88, with the new body style
 1986 Chevy K30(under repair)
Offline LTZ C20
« Reply #5 on: October 24, 2016, 12:19:04 am »
Figured that's what you ment but wanted to clarify just in case. I'm glad you chimed back in tho, because I couldn't remember what the newer pattern was, I got to 8x and drew a blank on the 180.
LTZ Cheyenne C20
« Reply #6 on: October 24, 2016, 02:58:02 pm »
its cool. i wasnt 100% clear on what i was saying and i have to be reminded sometimes that what i said wasnt clear.
Offline harcorshe
« Reply #7 on: October 24, 2016, 05:59:46 pm »
Excellent.  Thanks guys!
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Offline LTZ C20
« Reply #8 on: October 24, 2016, 10:41:43 pm »
Hahaha
LTZ Cheyenne C20
Offline LTZ C20
« Reply #9 on: October 24, 2016, 10:42:36 pm »
LTZ Cheyenne C20
