Author Topic: Fuel Sending Unit Question  (Read 6538 times)
Offline jamieaburch
« on: October 25, 2016, 07:39:47 am »
Just replaced fuel tank on my 79 and now fuel gauge reads empty. Is this a ground problem? The gauge was working before tank replacement.
Offline hatzie
Re: Fuel Sending Unit Question
« Reply #1 on: October 25, 2016, 08:59:22 am »
The sender wire is shorted to ground or the sender has failed.
Offline jamieaburch
« Reply #2 on: October 25, 2016, 09:07:56 am »
When you say sender wire is that the power wire?
Offline ehjorten
« Reply #3 on: October 25, 2016, 09:57:37 am »
There is a ground wire that goes to the top flange of the frame rail for the sender.  Did that get connected when you replaced the fuel tank?
-Erik-
Offline jamieaburch
« Reply #4 on: October 25, 2016, 10:06:15 am »
I had to splice it back together and now I'm thinking it may have come loose when I put tank back in. Can I ground the wire to the frame or does it have to ground to the tank
« Reply #5 on: October 25, 2016, 01:21:17 pm »
An open ground will cause the fuel gauge needle to swing past full to about 3:00 o'clock.  As hatzie stated, for the gauge to register Empty, the signal lead is effectively grounded (either directly or through a faulty sending unit).  @Jamieaburch, the signal lead isn't actually a power lead, although it does have measurable voltage on it.  Make sure that you didn't accidentally splice the signal lead to ground.
Offline jamieaburch
« Reply #6 on: October 25, 2016, 01:57:14 pm »
Thanks bd. I will check when I get home
