Author Topic: 1980 Chevy K10 Transfer case wiring  (Read 8348 times)
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« on: October 30, 2016, 12:30:07 pm »
I have been trying to look all over this site and other sites....I am trying to find the wires for the 4 wheel drive light...i have the switch on top of the transfer case but i can not find the wires or the right wiring diagram to locate where the wires run from.   Thanks
Re: 1980 Chevy K10 Transfer case wiring
« Reply #1 on: October 30, 2016, 01:31:17 pm »
The 4WD indicator switch is illustrated just to the left of the fuse box in the 1980 Wiring Manual.  The dashed lines mean the switch and indicator only apply to four wheel drive applications.  Check the engine compartment firewall for a two terminal connector that has white and black wires running down toward the T-case.  The T-case harness maybe dangling or may have been removed and discarded.
Offline 80Chevy4x4
« Reply #2 on: October 30, 2016, 04:16:30 pm »
Thanks a million..I will check it....It helps a lot.
Offline 80Chevy4x4
« Reply #3 on: October 30, 2016, 05:37:09 pm »
I found a black wire and white wire...it goes to a believe a relay....the number on the relay is 14014515   i look it up and it says it is a TCC relay....my truck never had a lock up convertor.....anyone know what this relay is for on the 80's?   thanks....i have been looking at the wiring diagram and can not find it.
Offline Kip
« Reply #4 on: November 12, 2016, 01:27:11 pm »
I have 79 K20 my 4wd light wire comes from under the dash runs under the mat and under the shift boot and it is black & white I know it's factory I've known the truck since it was new it has live a pampered life
