Author Topic: compression test disabling fuel and spark. need quick help  (Read 3966 times)
Offline Macaroni_Sackaroni
« on: October 31, 2016, 12:56:11 pm »
never did this before.
want to make sure im doing this right, im getting a little confused b/c the motor was swapped kind of weird on the truck.
fuel pump relay found inside cab. going to disconnect this.
and the thing with the red wire coming out of it, is the igintion coil and if i disconnect the red i disable the spark?
then i should be good to do the compression test.
Offline LTZ C20
Re: compression test disabling fuel and spark. need quick help
« Reply #1 on: October 31, 2016, 01:40:44 pm »
Yea that will work fine. Or pull the fuel pump fuse.
LTZ Cheyenne C20
« Reply #2 on: October 31, 2016, 01:48:01 pm »
 cant actually find the fuel pump fuse. i checked under dash nothing labeled fuel pump and nothing under hood. just a few random fuses next to the relay that are unlabeled. i suspect one of those are but i wouldnt know how to figure it out.
Offline LTZ C20
« Reply #3 on: October 31, 2016, 05:32:59 pm »
Then pulling the relay is fine. It's the same affect.
LTZ Cheyenne C20
« Reply #4 on: October 31, 2016, 06:06:32 pm »
yup. cool thanks
