Author Topic: Steering problems  (Read 19001 times)
Offline Zac.richardson1
Re: Steering problems
« Reply #15 on: November 15, 2016, 09:23:47 am »
It came with an aftermarket steering arm. It's only a little bigger than the stock steering arm maybe 2inch rise. Would a 4inch rise on the steering arm still be good?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #16 on: November 15, 2016, 09:41:16 am »
Please post a pic of the arm.
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
« Reply #17 on: November 15, 2016, 10:04:17 am »
Where is the best place to buy
Offline blazer74
« Reply #18 on: November 15, 2016, 10:38:14 am »
I've only seen one size. Then a block under it which I don't recommend. Try the arm and see how it improves your steering.
Check the site store then internet search.
« Reply #19 on: November 23, 2016, 12:59:56 am »
Got the new 4in steering arm in Saturday and it helped ALOT. There is still about a 2in angle on the draglink. Should a new pitman arm be mandatory or just bought asap.? Haven't got it on there to check cause I messed up the threading beating it off with a hammer, yes I hit the bolts with a hammer, stupid I know.
« Reply #20 on: November 23, 2016, 06:20:08 pm »
2 inch rise is fine, anything more you'll see the steering issues come back
« Reply #21 on: December 24, 2016, 11:39:57 pm »
put on the new draglink and steering arm but I still don't have full steering. Why?
Offline Greybeard
« Reply #22 on: December 28, 2016, 11:00:55 pm »
The more level the better as the drag link goes but don't lose sleep over it. Some bump steer is only annoying, lots of bump steer is dangerous. My take on the bent drag links is they need to be made illegal. An extreme angle between the two ends is always going to be an extreme angle even with a bent bar between them. Bring one end up and the other is stationary (simply put) and the distance between the ends changes, with a bent bar you get the same bump steer as you would if you used a straight bar between them. Solid is solid.
As far as not getting full lock to lock steering...that could be many things. Jack the front up and swing the tires while watching everything, see what may may be interfering. Then look at the bottom of the steering knuckles on the rearward side, there you MIGHT find a couple of bolts screwed into the axle housing and acting as stops for the steering arc. Doubtful but you might get lucky. Mine had them and making the turning radius slightly sharper was easy; but that's another thread.
If you followed Viles instructions on setting the steering box to center there shouldn't be any steering related reason why they won't turn lock to lock. Maybe hitting the oil pan? Toe set seriously poorly? The steering on a K truck is certainly not complicated. Steering wheel, steering column with associated parts, steering box, pitman arm, drag link, steering arm, 2 knuckles and a connecting rod. Not really much to it.
