Author Topic: Steering problems  (Read 19000 times)
Offline Zac.richardson1
Steering problems
« on: October 31, 2016, 06:34:32 pm »
After I put the 6inches of lift under my 85 GMC Sierra it turns most of the way to the right but barely turns to the left. I was told to adjust the drag link but I'm clueless on the topic. Some help would greatly be appreciated
Re: Steering problems
« Reply #2 on: October 31, 2016, 06:43:01 pm »
Looks like my problem. Thanks for the help
Offline Captain Swampy
  • Wisconsin
« Reply #3 on: November 01, 2016, 01:35:12 pm »
Your drag link should be level when your truck is sitting on the ground. Bedazzled has a 4" lift and a dropped steering arm ( the arm on the axle). You can also get a dropped pitman arm for the steering box. If your drag link is at an angle, you will get bump steer. The sharper the angle the worse it will be.
« Reply #4 on: November 07, 2016, 10:10:42 am »
I talked to a guy at rough country and he suggested a adjustable drag link. What do you think? Here's the link: http://www.roughcountry.com/adjustable-drag-link-6619.html
Offline blazer74
« Reply #5 on: November 08, 2016, 10:35:57 am »
Raised arm at the knuckle is good for 4-5, I have about this with just a slight angle on the drag link and Zero Bump Steer.
All my ballpoints are tight and proper preload.
Like said if you needed more than the dropped pitman arm added might do it.
The adjustable link says 4-6, no idea as far as durability goes tho.
Probably cheaper than both the others.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #6 on: November 08, 2016, 11:39:15 am »
Adjustable link is ok, geometry can still be off, but much better then it probably is now, best is a raised arm, followed by drop Pittman...actually best is crossover steering, but that's probably outside of this discussion.
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline blazer74
« Reply #7 on: November 08, 2016, 02:44:20 pm »
« Reply #8 on: November 08, 2016, 03:11:31 pm »
Have you set it correctly first? BTW the stock drag link is adjustable
« Reply #9 on: November 09, 2016, 06:58:54 pm »
I thought it was but I couldn't find anything on how to adjust it. As for it being set correctly, no. It turns way more to the right then to the left or vise versa I don't really remember l. What I do know is that the wheels aren't turning all the way and the drag link is no where near straight like it should be. The lift kit I bought had a new steering arm, but no pitman arm. Should I get a pitman arm? If yes what kind of pitman arm and how far of a drop? Where do I buy? Thanks
« Reply #10 on: November 10, 2016, 05:04:29 am »
When sitting on the ground the drag link should be level(as stated earlier) if it is not place a small level under the drag link an measure from the bottom of the drag link to the top of the level.  That will tell you what size drop pitman you need.
As to adjusting a drag link- remove 1 end(not really necessary unless you are hitting the bumps top on one side only.) you need to find the center of the steering box- turn wheel all the way to left or right, count the turns while turning the wheel the opposite way, divide by two and turn the wheel back that number, mark it somehow in case you knock later. Now with the two bolts on the sleeve of the drag link loosened(and bolted back up, adjust the drag link so the box is centered and the wheels point straight ahead. Use channel grips to twist the sleeve on the drag link.
« Reply #11 on: November 11, 2016, 04:58:09 pm »
The drag link is being a pain in the  and won't come off. Beat on it for about 2 hours and it hasn't budged any... i didnt have a level on hand so i made due and it seems to be inbetween a 6-8 inch drop. does this sound about right for a six inch lift?
« Last Edit: November 11, 2016, 05:13:23 pm by Zac.richardson1 »
« Reply #12 on: November 13, 2016, 08:58:08 am »
Why are you beating on the drag link? What do you need a level for? The drag link does not need to be leveled with a level. If the angle is too excessive either put the correct steering arm on, use a drop pitman or use the offset drag link. I prefer the steering arm and a straight drag link for ease of adjustment.
If you are trying to remove it, take out the cotter pins and castle nuts. Strike the steering arm and the pitman arm where highlighted in the pic or use a pickle fork. do not hit the drag link or the threads on the ball stud.
« Reply #13 on: November 13, 2016, 10:25:33 am »
I'm trying to find what size pitman arm I need
« Reply #14 on: November 13, 2016, 04:12:09 pm »
If it's a 6-8" drop, then you probably need a 2" drop pitman with a 4" raised steering arm. You don't need a perfectly level drag link, but anything with more then 2" of drop affects steering.
