Author Topic: Removing glue @#%$ other residue  (Read 6983 times)
Offline gbskunk2006
« on: September 10, 2006, 10:34:00 pm »
What's the best way to remove the glue/residue left behind from the old side trim?  I'm prepping the body for paint, unfortunately sand paper gets all "gummed" up, and accetone just smears it around.
Thanks in advance.
[/URL]" />
Edited by: gbskunk2006 at: 9/13/06 2:23 pm
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline shaved80
Re: Removing glue and other residue
« Reply #1 on: September 10, 2006, 11:30:00 pm »
there are "eraser wheels" that attach to die grinders, take one of them to it and it'll be smooth like a babys butt
Edited by: shaved80 at: 9/10/06 10:33 pm
Offline bfofish
« Reply #2 on: September 10, 2006, 10:32:00 pm »
i've used a heat gun and a putty knife to remove that stuff before.or you can try some Goo Gone   you can find it just about any place like Walmart,Kmart,home Depot ect...
« Reply #3 on: September 11, 2006, 05:23:00 am »
I use a single edge razor on a foldable holder. take all the heavy stuff, then I use laquer thinner. Rub it till it smears good then wipe off with a dry rag. it takes some elbow grease but works.
Offline Z28 c10
Re: Removing glue @#%$ other residue
« Reply #4 on: September 11, 2006, 04:41:00 pm »
denatured alcohol always worked for me. if you have a cabinet shop anywhere around you ask them for about a quart of Lacthol. thats what just about every shop uses for adhesive removal, it won't burn your hands like lacquer thinner will either.
 JayTater
 Z28 C10
Offline 75 C20
« Reply #5 on: September 11, 2006, 07:33:00 pm »
i used a a heat gun and a putty knife 2. it worked really slcik and got it all nice. just be sure too make sure all of it gets reall hot then it will just scrape right off.
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
