Author Topic: Rebirth of Sandy  (Read 139635 times)
Offline jpizzle440
  • avid motor head
Re: Rebirth of Sandy
« Reply #15 on: November 05, 2016, 05:13:04 pm »
Brackets and fuel lines off.
83 4door c30 dually 454/400
86 c10 swb 5.3/4l60e
86 k10 swb 454/th300
85 4door k30 327/sm465
77 c30 single wheel 454/sm465
Offline jpizzle440
  • avid motor head
« Reply #16 on: November 05, 2016, 07:38:58 pm »
Got her out. Time for more cleaning and painting.
« Reply #17 on: November 06, 2016, 07:12:54 am »
Nice! Are you gonna run the 5.3 or the 6.0?
5.3/4l60e
The 6.0 is going in this guy.
now why would you put a 6.0 into this guy???
i dont care how much i hate someone i wouldnt do that to someone ::)
Offline jpizzle440
  • avid motor head
« Reply #18 on: November 06, 2016, 10:27:47 pm »
E-brake, fuel line, and leaf spring shackle brackets.
Offline jpizzle440
  • avid motor head
« Reply #19 on: November 07, 2016, 07:03:36 pm »
Ball joint puller works pretty good popping bushings out. More cleaning. Got to replace axle seals. Was leaking when I got it.
Offline jpizzle440
  • avid motor head
« Reply #20 on: November 08, 2016, 03:47:52 pm »
New arrivals
« Reply #21 on: November 08, 2016, 06:33:19 pm »
Looking good. Firewall might look better in semi-gloss
Offline jpizzle440
  • avid motor head
« Reply #22 on: November 08, 2016, 07:19:28 pm »
  Going to go a different color with everything next year. Right now jusy matching whats on it. I need to get it back together.
Offline jpizzle440
  • avid motor head
« Reply #23 on: November 08, 2016, 07:22:08 pm »
Mounts back on.
She broke on me, got lucky and spun it right out with a scribe.
Offline DustyRusty
« Reply #24 on: November 08, 2016, 10:18:32 pm »
Nice save!  It's great to see these old trucks be reborn.
Your photo documentation is great.  Keep up the great work.
To cover up my wiring from paint, I used aluminum foil rather than tape - it's a little easier and quicker to remove.  Just a thought.
It looks like you taped and identified the electrical connections.  Good call.
IIRC, the wiring diagrams are located in the Tech section.
Rusty
PS:  Sent you a PM
« Last Edit: November 08, 2016, 11:27:27 pm by DustyRusty »
Customized by rust.
Offline jpizzle440
  • avid motor head
« Reply #25 on: November 09, 2016, 11:11:25 am »
Rusty
PS:  Sent you a PM
I should have thought about using foil. Thanks for the tip. Yes I know about the diagrams, I'll look it up after I get everything done. For now that section of wiring is staying on the transmission.
Offline jpizzle440
  • avid motor head
« Reply #26 on: November 09, 2016, 01:39:32 pm »
4$ bolt
More goodies
Plastic hood cowl, battery tray, top radiator mount, steering wheel... but this I'm not happy about. New brake lines...
Here is the new wheel. Pics of the other stuff will come as the go on.
Now back too reassembling and cleaning this guy.
« Last Edit: November 09, 2016, 04:06:37 pm by bd »
Offline jpizzle440
  • avid motor head
« Reply #27 on: November 09, 2016, 03:16:40 pm »
Another box of goodies.
Some painting.
Offline jpizzle440
  • avid motor head
« Reply #28 on: November 09, 2016, 04:48:31 pm »
Cleaned up gasket surface and around it so I don't hit the pan with wire wheel.
Painted.
Offline jpizzle440
  • avid motor head
« Reply #29 on: November 10, 2016, 04:51:13 pm »
Started the leafs.
Windows pissers and rear brake lines bracket.
Cleaned, taped, primed. Waiting on it to dry to flip flop it.
