Author Topic: 1988 K20 suburban back window wont go back up using any switches  (Read 3338 times)
Offline MuddiGGEr25
  • Wrencher
« on: November 03, 2016, 11:36:58 pm »
My nephew got the right rear side window to roll down while trick or treating and it wont go back up no matter what i do, and its going to be dropping below freezing agian soon.
I can only control the two drivers windows from the drivers door control.
Does anyone know which wires i can just connect 12V+ and ground to, and be able to manually send the motor and window up? I have a extra set of mini jumper cables and a spare truck battery to use so i can completely bypass the suburban wiring.
I already have the 5 wire connector hanging out
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Re: 1988 K20 suburban back window wont go back up using any switches
« Reply #1 on: November 04, 2016, 07:14:43 am »
get a helper and see if youre getting any power to the switch then use the drivers switch to try and move it while probing the wires for power
Offline hatzie
« Reply #2 on: November 04, 2016, 09:12:45 am »
Download the 1988 wiring diagrams.  They'll show you what connections go where.
