Author Topic: Stock radio with aftermarket speakers on 84 K10  (Read 7761 times)
Offline temains
« on: November 09, 2016, 04:53:25 am »
Can I run new 6x9 speakers in my cab corners and keep my stock head unit?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Stock radio with aftermarket speakers on 84 K10
« Reply #1 on: November 09, 2016, 06:00:47 am »
I don't remember how many outputs are on the stock unit, but it shouldn't matter otherwise.
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
« Reply #2 on: November 09, 2016, 06:15:48 pm »
pretty sure you can but theres a conflict between the new speakers and your old head unit. cant remember off hand but try the search
Offline temains
« Reply #3 on: November 14, 2016, 04:49:58 am »
Does anyone know if i can run new 6x9s in my cab corners off my original radio
« Reply #4 on: November 14, 2016, 06:51:19 pm »
yes you can run 6x9's
Offline OldGray
  • Ne'er-do-well
« Reply #5 on: November 15, 2016, 12:33:11 pm »
Yes, you can run 6x9's in the corners.  Did you know you can also add bluetooth to your old stock unit?  It's pretty cool (and cheap)!
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32675.msg277070#msg277070
1979 Chevrolet Bonanza / 305 / LWB
« Reply #6 on: November 15, 2016, 12:39:40 pm »
The stock radio uses 10-16 ohm speakers.  Many of the speakers out there are 4 ohm causing a lot of strain on the Delco stock radios.  While it will work that is the leading cause of stock radio's to stop working.
« Reply #7 on: November 16, 2016, 07:19:47 am »
this is what i was talking about. thanks zieg
