Author Topic: Electrical poltergeist (ground issue?) - instrument panel, lights...  (Read 4571 times)
Offline SeeTenn
Having what I believe to be a bad ground issue(?) that I can't track down. Was wondering if anybody had a similar problem. Not really in a position to do a complete frame off disassemble chasing this down.
Drove to work last Friday, no problems. Had not done any work on the truck in a while.
Got in after work, turned on the headlights and ALL the exterior lights came on.  Low beam, high beam, reverse lights - whether switch just pulled out to parking light position, fully on, and high beam selector - didn't matter.  Also, both turn signal indicator lights in dash are lit up and buzzer is buzzing. Disconnected high beam relay (  heavy duty direct wire kit) to drive home.  Also, driver side window wouldn't roll down. Relays were clicking but nothing was happening.
Got home, found that fuse for window motor blown only on the one side. Motor power direct wired to battery with   heavy duty window kit.  This doesn't share a ground with anything else, and I inspected the wires for breaks, cuts, etc. and no problems. Replaced fuse and it's been ok.
Trying to track problem, found that if I pull the T/L CTSY fuse the dash light/buzzer problem goes away, but unfortunately I have no tail lights. If I pull the 5amp INST LPS fuse, the problem pretty much goes away, I just don't have dash lights. I've been running it this way and everything is fine except dark instruments at night.  I replaced the headlight switch with a new delco unit but, of course, that was not the problem.
I completely disconnected all non-factory circuits, but it made no difference.  I checked and/or added new grounds wherever I could, but nothing seems to help.  The most recent work was rear brake work that has me without a parking brake right now, but that was a couple weeks ago. Thought maybe the parking pedal going to the floor knocked something loose, but no.  Also, appears the parking brake idiot light connector was long ago removed.
I have no idea what kind of power surge happened at work to blow the window fuse and make everything go crazy. Everything is find without the instrument fuse in. I know that bad grounds make juice flow to wherever a ground can be found, and I thought maybe enough was bleeding in or out of the INST LPS circuit to trigger the headlight relays through the switch and light up the turn signals.
Anyway, any help would be greatly appreciated.
Thanks!
Offline TurboJim
  • idontknowwhatishouldputhere...
Re: Electrical poltergeist (ground issue?) - instrument panel, lights...
« Reply #1 on: November 14, 2016, 08:30:34 am »
It seems to me that there might be a problem with the wiring harness plug that goes through the firewall on the drivers side. If it burned, or something got in it to short  it out that could be the problem.
Currently owned:1989 Chevrolet R3500 3+3
TBI 454 THM400 transmission dana 70
1992 Pontiac Firebird convertible 3.1L THM700r4 Previously owned:1992 Chevrolet c/k3500 454 4l80E (it got hit august of 2016 and was totaled)
never cruel, never cowardly
Offline SeeTenn
« Reply #2 on: November 20, 2016, 12:16:00 pm »
Still chasing it down, still no luck.
Except now headlights on both sides flash when I use the left turn signal.
Maybe that's why all those other people don't use their turn signals either....
Offline SeeTenn
« Reply #3 on: January 19, 2017, 12:18:59 am »
Follow up.
So after searching high and low, isolating individual circuits, found a few problems.  One problem was a messed up rear harness. B12 applied with a wire into the socket for the rearmost harness (by rear bumper) showed both tail lights lighting up. Not cool. Inspected wires, couldn't find any problems so eliminated connectors and wired mid and rear harnesses together. Fixed most of the problem.
Also, the wee little passenger front market light bulb was messed up, one filament, probably hitting the working one. These lights don't have direct ground, so that was a problem I noticed when isolating circuits.
Couldn't figure out why power window had blown fuse, was a nagging problem...
Everything was looking good and dry weather for once so I took it for a drive today.  It all looked good. Then I noticed on my cheapo triple gauge 16 volts.
So yeah. Looks like it was a bad voltage regulator.  Still had the stock delco alternator. Getting a new one tomorrow, I suspect (hope) that will be the end of it.
If you're reading this trying to figure out your problem, hang in there and be methodical. Glad I didn't beat the heck out of the truck with a sledge hammer like I wanted to a few times. AND KEEP YOUR EYES ON YOUR GAUGES!!! There's a reason you installed that triple pod under your ashtray.
