Author Topic: Replacing window seals  (Read 12452 times)
Offline boonzo
« on: September 28, 2006, 12:54:00 pm »
:rolleyes  Hey guy's,
I just bought an '85 silverado and the window seals are shot and I would like to replace them...but how do you go about doing that? Is there a special tool needed?
Thanks
Offline 123 pugsy
Re: Replacing window seals
« Reply #1 on: September 28, 2006, 11:56:00 am »
Which window?
Pugsy
76 C10 LWB
TPI 350
Offline boonzo
« Reply #2 on: September 28, 2006, 12:31:00 pm »
That would be the drivers and passengers windows...
Offline roundedline
« Reply #3 on: September 28, 2006, 01:12:00 pm »
If you are talking about the inner outer weatherstripping that attaches to the door panel and the outside door lip you don't have to remove the window.
If you are talking about the vent channel, it will be easier if you remove the vent assembly.
If you are talking about the window sash channel, you don't have to remove the window for that either if you can get your hand in there to seat the channel.  I just did this a few weekends ago and took some pics for a tech article.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline boonzo
« Reply #4 on: September 28, 2006, 01:23:00 pm »
that helps, it's just the outer seals I'm concerned about for now.  I was looking at them yesterday trying to figure it out and I saw the clips and couldn't figure out how to get the clips out of the channel to pull the seal out.  Also, do you have a link to those pics, I'd like to check'em out?
Offline roundedline
« Reply #5 on: September 28, 2006, 03:21:00 pm »
Offline boonzo
« Reply #6 on: September 28, 2006, 08:18:00 pm »
Well I was attempting to post a pic of the bad seal but I can't seem to figure out how to upload on this post, insert image ain't to user friendly!!! Oh well.....
Edited by: boonzo at: 9/28/06 7:23 pm
Offline roundedline
« Reply #7 on: September 28, 2006, 07:22:00 pm »
Files have to be uploaded to the internet to post them.  You can't like from your personal PC.
Project Su
Jimmy 2WD Project
Offline boonzo
« Reply #8 on: September 28, 2006, 07:25:00 pm »
That's what I figured....I'll see if I can come up with something...
Offline roundedline
« Reply #9 on: September 28, 2006, 08:35:00 pm »
The ones at the top of the door panel and the outside of the door right?
They pull off with a little tug.
The ones connected to the door panel require a little more care since you can break the door panel when the clasp on.
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 9/28/06 7:36 pm
Offline boonzo
« Reply #10 on: September 28, 2006, 08:38:00 pm »
Illegal javascript event tags or url parameters detected.
Darn thing doesn't like my pic link!!
Edited by: boonzo at: 9/28/06 7:40 pm
Offline boonzo
« Reply #11 on: September 28, 2006, 07:42:00 pm »
Thanks for that info Chris, I think I'm getting the idea now
Offline DnStClr
« Reply #12 on: September 30, 2006, 11:40:00 am »
Quote:
BTW, if you ever replace the vent windows, you'll have to remove the big windows to do that.
That isn't actually 100% true.  It is possible to do it.  I pulled my vent windows out without the main glass and replaced all the weatherstripping and put it back in.
Don St.Clair
Culleoka Tn
Edited by: roundedline at: 10/2/06 3:04 pm
Don
87 Chevy Silverado
